I just scraped off the film and put leds in my dash and now I'm having major electrical issues like no odometer, speedometer, tach, passenger window won't roll down, radio don't light up, lights flicker when I depress the brakes and my dome lights boogered up! Please help!!
Like on the back of the cluster? Lately my psom and my fan lights have been flickering when I have the headlight **** turned all the way up... When I turn it down it don't do it.. Could that have sometbing to do with it?
Would the headlight switch cause the passenger window to not roll down? Or to have hardly any light or of the some light? And the gauges to not function
the ground for the cluster I believe is located under the hood, passenger side cowl. Can't miss it next to the hinge lift for the hood.
The other ground is located near the battery, another located right of radiator, driver side core support, next is by the EEC diagnostic connector.
The following are ground strap areas. One located down under the frame , core support to frame, passenger side, another one just at passenger door under truck of the door.
