Led swap gone wrong!
Old 01-23-2015, 07:25 PM
1993_f350_2013's Avatar
1993_f350_2013
1993_f350_2013 is offline
I just scraped off the film and put leds in my dash and now I'm having major electrical issues like no odometer, speedometer, tach, passenger window won't roll down, radio don't light up, lights flicker when I depress the brakes and my dome lights boogered up! Please help!!
Old 01-23-2015, 09:07 PM
Puddy's Avatar
Puddy
Puddy is offline
Is the plastic ribbon cable seated correctly in the housing?
Old 01-23-2015, 09:54 PM
1993_f350_2013
Like on the back of the cluster? Lately my psom and my fan lights have been flickering when I have the headlight **** turned all the way up... When I turn it down it don't do it.. Could that have sometbing to do with it?
Old 01-23-2015, 10:31 PM
Puddy's Avatar
Puddy
Puddy is offline
If it's doin that when your dimming, replace your headlight switch asap... Unless you like fire hazards.
Old 01-23-2015, 11:02 PM
Crewcabber's Avatar
Crewcabber
Crewcabber is offline
Something went wrong but what you are describing shouldn't have anything to do with the cluster and leds.
Old 01-23-2015, 11:36 PM
1993_f350_2013
I took the switch out when I had the cluster off and the plug and whatnot look great (no melting or anything)
Old 01-23-2015, 11:38 PM
1993_f350_2013
Would the headlight switch cause the passenger window to not roll down? Or to have hardly any light or of the some light? And the gauges to not function
Old 01-24-2015, 12:58 AM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Sounds like a bad ground somewhere
Old 01-24-2015, 01:00 AM
1993_f350_2013
Like in the cluster? Or a wire that runs to the back of the cluster or headlight switch?
Old 01-24-2015, 01:03 AM
Diesel_Brad
There are grounds all over the truck. I would start checking them all
Old 01-24-2015, 01:07 AM
1993_f350_2013
Alrighty.. Thanks brad! Now when I try to start it my starter just clicks.. It might have a dead battery though..
Old 01-24-2015, 01:34 AM
timbersteel's Avatar
timbersteel
timbersteel is offline
Starter clicks or fender-mounted solenoid just clicks?
Sounds like a bad ground.
Old 01-24-2015, 01:37 AM
1993_f350_2013
Everything worked before I took the cluster out.. Where's the grounds located around the cluster?
Old 01-24-2015, 01:49 AM
timbersteel
the ground for the cluster I believe is located under the hood, passenger side cowl. Can't miss it next to the hinge lift for the hood.
The other ground is located near the battery, another located right of radiator, driver side core support, next is by the EEC diagnostic connector.
The following are ground strap areas. One located down under the frame , core support to frame, passenger side, another one just at passenger door under truck of the door.
Old 01-24-2015, 01:57 AM
timbersteel
Ground "H" is the Instrument Cluster ground. It is located "Behind Bottom of Right Cowl Panel"
I believe that "Right" refers to passenger side. I have looked in the past and haven't found this on the driver side.
Quick Reply: Led swap gone wrong!
