Putting new head gaskets on my 6.7
Yes doing it myself. It's not the egr cooler, has been deleted, egr deleted, dpf deleted. Has H&S mini maxx on it, on stock setting. They are asking 800.00 to 1000.00 for ARP studs. Got new head bolts for 50.00. Went thru 3 turbos under warranty. Took this turbo off has a lot of play and leaking oil. Buying a new one to go back on it.
Reps sent brother!!! Thank you for taking pictures! I assume you are mechanical in a sense or you wouldn't have been able to do it. You think you blew it while towing with it tuned??
Thanks for the info on the turbo, didn't know that. I have already purchased the same one that's on it though (BC3Z 6K682A). Learned there were a couple of turbos for that year. Also learned that a cab and chassis turbo is different (BC3Z 6K682B), than one for a pickup.
I tried to ask three ford dealors parts counter, what was included in a valve grind kit they sell. None of them could tell me what exactly was in it. They all were guessing. They have two kits if your doing head gaskets. One if you are doing it in the truck with cab off, one if your pulling the motor and doing head gaskets out of the truck. I ordered the one if your pulling motor, came with more stuff. When I got it, did not come with valve seals, head bolts, valve cover gaskets. Does come with turbo seal, intake seals, fuel injector lines, orings, bolts. Fuel filter,thermostat, exhaust manifold gaskets, torque convertor bolts, belhousing bolts, some other little stuff. (BC3Z 6079 B). The other kit last letter (A).
Bought head bolts, head gaskets, valve seals, separate.
I agree will be saving for future. I broke the bottom small turbo clamp when removing, that took some time. Was hard to get to and stuck. If you take out the passenger side fender well, helps you see it. I ordered a new one, ordered a new thermostat, and exhaust gaskets. They were all in the kit, so got a refund on those parts. Came with all three new turbo pipe clamps, exhaust studs. Came with new flywheel bolts also.
Going to buy new glowplugs. Would like to put in new injectors at this time, but cost is holding me back, (about 3500.00 to 4000.00).
just throwing it out there. Is it at all possible that the gasket could have blown due to gunk'd up coolant. i mean if the coolant gets to thick then it wouldn't be able to make its way through the passages and thus causing the build up of pressure. I only say this because i thought the manual says to change the coolant after 5years/200000 miles? I just find it hard to believe that a stock tune could cause this to happen.
