'50 OEM Bed Assembly
Disassembling my late '50 f1 and I am about to do the bed. As I am talking to my Dad about unbolting the sides from the end, he says "as far as I remember, the bed sides were spot welded to the cab end wall on my '50."
So, how were the bed walls originally assembled at the factory? Welded or bolted?
It is very possible I have an after market bed, but I am a purist when it come to restoring a vehicle so I want "original" (looking) when possible.
If welded, who and/or where is a good supplier? Mar-K, Mid-Fifty? They seem to be the favorites on previous threads.
Thanks
Dan Sokol
Goodyear, AZ
Thanks
Dan Sokol
Goodyear, AZ
Thanks
Dan Sokol
Goodyear, AZ
Thanks
Dan Sokol
Goodyear, AZ
Dan, all the stuff I remember the beds side and bulk head were welded together. fenders, & light. I heard that tailgate pivots were mounted both ways, some were bolted on, others were bolted and welded on both.
In taking the fenders off, the bolts didn't fare so well so I had to grind them off. That was not fun.
So sometime during the '48 to end of '50 run, the bed walls went from riveted to spot welds. My guess would be when they stopped installing the sheet metal floor over wood during the 1950 production run. Mine being a late '50 run would make it spot welded sides to bulk head under that theory.
Now, how would that be best duplicated with reproduction parts available today?
Dan Sokol
Dan Sokol
Unless you are a purist, or your truck will never see anything but warm sunny days, you may want to consider just using small round-head torx or allen bolts. That way if any rust or dent damage comes your way, your life will be much simpler, and except for the allen or torx hole, they don't look too different than rivets.
Don52M3
01-22-2019 09:02 PM
hillbilly1951
69
10-09-2012 08:02 PM
Retired_Colonel
12-21-2009 09:00 PM
