Lost braking power
Checked it this morning. Pulled the vacuum line off the master cylinder drum and am getting suction. However, it doesn't seem all that impressive. It will stick to my finger but, comes off easily. I first noticed this 2 weeks ago when I removed my vac pump to change my fuel pump. It eventually regained power brakes within 20 mins. Been fine ever since. Then, on the way home from a camping trip (while towing), I went to make that last turn off the highway and had to stand on it to slow.
I will be sure to double check that. I know it was tight after re-install and after an initial double check. My plan is to also start checking suction at every junction from the booster, back to the pump as well. I have some time to work on it tomorrow.
#28
The vacuum pump may well be the problem; as they get old, they suck less and less - takes longer and longer to build up pressure in the reservoir(metal can).
It doesn't take that much to turn that pully, so while the belt should be reasonably tight, it's not nearly as bad as the power steering pully.
#29
I gave new/reman vacuum pumps a quick look online and they're over $100! So much for a "cheap" fix...
#30
Lost braking power
If it helps any... $100 is nothing compared to not quite stopping in time and effing up your truck or someone's family.
