How far do you have to go before your heater starts working?
It's a simple issue of mass and combustion. The V10 weighs around 600 lbs and has a less efficient combustion cycle than the 1,000 lb PSD. An extra two quarts of coolant doesn't make a darn bit of difference.
on
I don't think so. You can't heat up 60 lbs of coolant without also heating up 1,000 lbs of iron and steel. Heat goes from the cylinder to the block where it's picked up and circulated by the cooling system. That circulation evenly distributes the heat around the engine block until it gets warm enough to open the thermostat and bleed heat through the radiator.
Diesels have higher thermal efficiency than gasoline engine (a higher percentage of the diesel is converted to work rather than heat). So there is less "waste" energy in form of heat that goes into the coolant. This is another reason it takes longer for diesels to heat up in addition to those already mentioned.
#29
#30
Here in the midwest, I love my V10. At -6, I can fire it up, punch the butt warmer and leave the heat off. By the time I've scraped the windshield the temp gauge has popped up. With front and rear blasting I can be in short sleeves and jeans in less than 5 miles. If a big gasser is taking forever to heat, might be a good time to have your coolant checked.
As a truck driver I can tell you a diesel isn't gonna get hot until it idles awhile. Best advise for PSD owners is let it get the oil circulated and go. Putting it under load is the only way to heat it up fast.
