1963 Ford F260 info
1963 Ford F260 info
hello this is my first post on here i'm looking for any info i can get on 1963 ford f260. here is what i know so far. this is the one i own. all so how many ford f260 were made in 1963
Warranty # / S.N F26CR
F26- Series<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
C- Engine (292 2V)<o></o>
R- Assembly plant (San Jose)<o></o>
Wheel base- 120” (10’ feet)<o></o>
Color- M (Corinthian white / Paint spec #M30J-1238)<o></o>
Model- F260 (F250 Factory 4x4)<o></o>
Body / Cab Type- 81B (Conventional Closed Cab-Custom) red and white
Transmission- F (4 Speed Warner T98-A)<o></o>
Axle Rear- 24 (Ratio and Rating 4.56- 5M) Dana 60?
Axle Front- B (Ratio and Rating 4.33- 34M) Dana44 Closed Knuckle Front Axle (GAWR-3500)<o></o>
Max G.V.W LBS- 6600<o></o>
Cert Net H.P- 135<o></o>
R.P.M- 3800 <o></o>
D.S.O- 741542 (74- Seattle) (District code /Special Order #) (Trucks built to Domestic Special Order (D.S.O) have the order# and the District Code # of the district which ordered the unit stamped inthis space. If the truck is regular production unit, only the District Codewill appear
My truck also has these on it. (Where they optionsback in 63)?
The Drum is 8 lugs instead 5.
10 leaf springs in the back, 6 in the front
Factory heater
It has 4 tail lights instead of 2 . 2 right, 2left all are round tail lights. The extra tail lights are different then thefactory ones and look professionally installed.
Also does it having D.S.O # make it rare?
any info would be great
R.P.M- 3800 <o></o>
Factory heater
F250 had 8 lugs - F100 had 5 lugs
The upper two might be reflectors. Both of my 1966 4x4 trucks have the round taillights below the factory installed reflectors that are also round, but screwed to the surface rather than recessed like the taillights.
Here's a couple picture of one of my trucks to show what I'm talking about.
Here's a shot from the 1964-1972 MPC showing the reflectors. I went back to the 1957-1963 MPC to see if I could figure out the part numbers for those lower lamps and don't see anything like it. 1961 and up calls out the same reflector and shows it in the same location as my truck. Hadn't seen anything like yours before.
Click to enlarge the picture. For some reason it did something different today.
The V-8 hood emblem was swapped in from the original lightning bolt and gears emblem. The V-8 was 1965-66 V-8 only. A nice touch, don't change it unless you want her totally stock, just an FYI. There's a bunch of posts with the same info, but here's a sample I picked out where ND gives the good info, just so you don't think I'm making stuff up. Lol...
https://www.ford-trucks.com/forums/1...od-emblem.html
