Oil Cooler Deleted, pics inside
Old 05-01-2015, 01:14 PM
Snipeston's Avatar
Snipeston
Snipeston is offline
Originally Posted by ponykilr
If you could figure out a hose that would work it could be left in place, but I do not see this being possible.
What if i just ran the non-oil cooler hose from the radiator to tue water pump and just left the hose nipples of the oil cooler open to the air?
Sorry, not familiar with the internals of the oil cooler and common failure points...
  #32
Old 05-01-2015, 01:18 PM
jas88's Avatar
jas88
jas88 is offline
I removed the cooler on my 460 because my F150 frame was not chamfered for it. I did a similar install to yours except I mounted the filter up behind the bumper to protect it. I used braided SS hoses from Summit.
My next door neighbor bought a '94 F150 for his daughter and it has the 351W. When he got the truck, the cooling system was rusted very badly, so I recommended we remove the cooler lest it fail. It's still sitting on my workbench. We just replaced his lower radiator hose with one for a 302.
  #33
Old 05-01-2015, 10:05 PM
Big_Al59's Avatar
Big_Al59
Big_Al59 is offline
Thanks to OP for bringing this up, hadn't heard about it before. I did confirm today my rig has one on it. I'll be removing it, just not sure on method yet.
  #34
Old 05-02-2015, 12:57 AM
GuitarJesus's Avatar
GuitarJesus
GuitarJesus is offline
I replaced mine with the version from the bricknose era trucks.
  #35
Old 05-02-2015, 09:36 AM
Scndsin's Avatar
Scndsin
Scndsin is online now
Originally Posted by Snipeston
What if i just ran the non-oil cooler hose from the radiator to tue water pump and just left the hose nipples of the oil cooler open to the air?.
1)The sandwich plate (part with 2 hose nipples) can be removed from the block. It has a metal tab to keep it from rotating. Bend it & unscrew.
2)The nipple that the filter screws onto can be removed with the appropriate size hex/allen wrench from the sandwich plate. Screw that back into block.
3) Use a standard non-oil cooler lower radiator hose.
4) You can now use full size filter, (Usually FL-1A)
Here's the sandwich plate being removed from my 5.8:
Here's the Transdapt dual setup I mounted on the framerail:
  #36
Old 05-02-2015, 12:38 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Correct me if I am wrong but didn't the 87-91 trucks have a cooler but a different design?
  #37
Old 05-02-2015, 12:42 PM
GuitarJesus
Yes they did Brad. They had an air-cooled unit mounted on the driver's side of the core support.
https://www.ford-trucks.com/forums/1...-addition.html
  #38
Old 05-02-2015, 03:19 PM
Diesel_Brad
Ok. Thanks for the write up. I think I am going to try an source one of those
  #39
Old 05-02-2015, 03:24 PM
GuitarJesus
If you can't, let me know. Lkq is having a 1/2 off sale in 3 weeks by me, they have a ton of 87-91 trucks, usually more than 92-97. I'm going anyway. All the items were light weight enough that shipping would be fairly cheap to PA. I'll also keep an eye out for that tailgate emblem you had been looking for.
The pain in the butt was the gasket for the oil cooler manifold. It wasn't the same as the old oil cooler i believe and not the same as an oil filter gasket.
  #40
Old 05-02-2015, 05:06 PM
Diesel_Brad
OK< thanks. But I THINK the yard come to me just got a brick F350 and I am pretty sure it is gas
  #41
Old 05-02-2015, 05:24 PM
GuitarJesus
Also I know at least some 85' and 86' Bullnose trucks got them. So that may help if the brick has been stripped down.
  #42
Old 05-02-2015, 09:03 PM
Snipeston's Avatar
Snipeston
...but what if I unhooked the hoses and just left the cooler there? is there any problem with doing so?
  #43
Old 05-02-2015, 09:18 PM
Scndsin's Avatar
Scndsin
Not really. Theoretically the sandwich plate could still rupture & blow the oil out rather than becoming contaminated with water . You still wind up using a 1/2 size filter.
justplumducky
10-14-2017 12:59 PM
Phil527
09-14-2010 04:08 PM
fordberg
04-04-2004 09:31 PM
Sportdeck262
03-06-2003 12:15 AM
TonyG
Oil & Lubrication
08-01-2002 08:16 PM
Quick Reply: Oil Cooler Deleted, pics inside
