what is the breaking piont of the 7.3 ??
Old 01-22-2015, 10:18 AM
trevorrules's Avatar
trevorrules
trevorrules is offline
what would the breaking point be of a obs 7.3 , without using nos/propane and the tranny blowing up????
Old 01-23-2015, 08:15 AM
tjc transport's Avatar
tjc transport
tjc transport is offline
i ain't rite
Received 3,102 Likes on 2,164 Posts
are you asking what will kill it ?
not changing the oil, or putting gas in it.
other than those two things, they will last pretty much forever if maintained properly.
Old 01-23-2015, 08:39 AM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Power stoke or IDI?
IDI will cavitate if the coolant is not kept in check
Old 01-23-2015, 09:35 AM
'89F2urd's Avatar
'89F2urd
'89F2urd is offline
what brad said....which are you talking about?
and what are you asking, what the power ceiling is or when the tranny will grenade? what trans???
need variables defined.
Old 01-23-2015, 09:43 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT
FORDF250HDXLT is offline
the 7.3l is so legendary that there is no point of failure known to man.
its rumored that once you put around 1 million miles on them,they self reman.
someone claimed they broke one once,but it was latter confirmed a hoax.
The following users liked this post:
Old 01-23-2015, 11:24 AM
dixie460's Avatar
dixie460
dixie460 is offline
That's funny right there. And I ain't even started drinking yet.
Old 01-23-2015, 03:04 PM
trevorrules
I meant adding hp , how much could it handle (powerstoke models) before throwing a rod or crank ??????
Old 01-23-2015, 03:23 PM
Diesel_Brad
That depends on the tuner and what year 7.3 you are talking about.
the 94-2000 have factory forged rods and are "good" to 550hp
the 01-03 have Powdered Metal Rods(PMRs) and are only "good" to 425.
But the trans is the weak link. Stock e4OD is only good for the stock 225hp and even then they were still not what I call reliable. Most guys after putting a chip in would blow the trans with only 50-65 extra HP
Old 01-23-2015, 05:03 PM
'89F2urd's Avatar
'89F2urd
'89F2urd is offline
Unless you have a good job, you'll break the bank before you break a 7.3. They're good for 300-350 wheel with a tune, after that it starts gettin very pricey per hp.
ZF5 is a very stout 5 speed that needs very little attention, if you are fortunate enough to have one vs an auto.
That's all in addition to what Brad said above.
Old 01-23-2015, 05:19 PM
trevorrules
I thought the e40d was a strong tranny!!!???
Old 01-23-2015, 05:41 PM
Diesel_Brad
Not stock, No. Not even close. but they can be BUILT to take 1000+ HP
Old 01-23-2015, 09:11 PM
trevorrules
is it the torque converter that causes it to be weak? cause I had my tranny rebuilt and they put a aftermarket torque converter that was stronger than the last one ( original ), my truck is actually in the tranny shop now so with in like a week ill be able to pick it up and ask them how much hp its rated at
Old 01-24-2015, 01:02 AM
Diesel_Brad
Torque converter is part of the weak link. There are multiple other weak areas like aluminum parts in the trans. Typical BUILDS replace the aluminum parts with steel pieces. Then there are also cryo shafts that can go in to, along with better clutches, MORE clutches, higher pressure valve body and tuning for the trans as well.
I am sure your local trans shop does not rebuild/build them for anything of great HP
Old 01-24-2015, 09:26 AM
trevorrules
I just wanted something better than 50+ hp without blowing the tranny out just some modest power but not crazy power....imma do that later on with a different 7.3
Old 01-24-2015, 09:36 AM
FORDF250HDXLT
your trans guy will be rebuilding to at least '95 spec with several upgrades,including the converter.you haven't got a worry in the world braking that trans with your idi.
Quick Reply: what is the breaking piont of the 7.3 ??
