Go Back   Ford Truck Enthusiasts Forums > Misc. > Cooling, Heating, Ventilation & A/C
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Cooling, Heating, Ventilation & A/C SPONSORED BY:
Click Here
  #1 (permalink)
Old 07-21-2003, 05:24 PM
TMCALLISTER TMCALLISTER is offline
Garage is empty, add now
TMCALLISTER is starting off with a positive reputation.
Question Econoline - Rear A/C blowing Hot out floor vents
My rear A/C is not working. It's blowing hot air out of the lower vents when the A/C should be coming out of the upper rear vents.
I had this same problem last year, and they replaced a broken blend door and actuator. The part was under $50 but the labor was huge.
I'd like to fix it myseld this time, but I DON'T KNOW WHERE TO FIND THE BLEND DOOR.
Can anyone point me in the right direction, or to a good book or web page?
Thanks.
  #2 (permalink)
Old 07-21-2003, 05:30 PM
bluezukiboy bluezukiboy is offline
bluezukiboy is starting off with a positive reputation.
any local parts store should have that part and a book to help you should check for vacum first at the rear control
  #3 (permalink)
Old 07-21-2003, 05:33 PM
Thanks. I'm checking the parts store for a book after work tonight.
  #4 (permalink)
Old 07-21-2003, 07:18 PM
94van 94van is offline
94van is starting off with a positive reputation.
You don't say what year you have. My '87 had the shut off valve to the rear heater allow hot water thru all the time. I replaced it, and problem cured.
__________________
'94 E-150 Conversion Van 4.9 / C-6
'89 Mustang 5.0 - Original Owner
2010 Mustang Premium V-6
  #5 (permalink)
Old 07-21-2003, 10:00 PM
oops -- 1997 E350 Super Club Wagon V10 - 15 passenger
I picked up the Haynes Repair Manual, but no help.
Then repair note from last years repair said "Remove rear ac housing assembly to check for vent problem. Replace door and actuator"
I'm thinking it is behind the back left panels, where the rear ac unit is.
Tags
2003, ac, air, blend, blowing, blows, door, e150, e350, econoline, ford, hot, rear, troubleshoot, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
