Polyurethane bushings and mounts ??
#33
I'd still use a hole saw as I mentioned before. 1st one side of the oval and then the other side. It's OK to then use the hole saw as a reamer to clean all rubber out of the metal shell. The poly bushing is going to fit in that oval metal shell and not move. So if the I.D. of the metal shell ends up a little rough (not smooth) it won't wear out the poly bushing.
#35
After I removed the steel sleeve from the pivot bushing on my '77 F100 front disc brake I beams, that I swapped into my '69 F100, I took the saw blade out of my hacksaw and inserted the blade through the hole in the bushing.
I reattached the hacksaw frame to the blade and made a cut downward through the rubber bushing, stopping just short of getting the blade into the thin metal bushing shell.
I made three more cuts into the bushing like this, 90° apart, to 'quarter' the rubber bushing. After I knocked the first quarter of the old bushing out, the other three quarters came out of the metal shell without too much fuss.
....least, that's how I did it.
#38
#44
No power/air tools of any kind, I finally did the deed with the help of a local mechanic . He happened to be around working on a neighbor's car and I lent him some tools, so he pitied me and gave me a hand to take the bushing out of the arm (by BFH/chisel submission), which he recommended me to take off immediately, definitely the way to go.
