Noobie GP Question
Noobie GP Question
So as the cold mornings creep in my truck is taking longer and longer to start. I have replaced the GPR with a Stancor and seems to be getting the proper voltage.
Tested the GPs themselves and 6 of them were around 2 ohms the other 2 were around .4 ohms.
Would this be the cause of my truck taking longer to start?
If so should I replace just those 2 or all 8?
Also my check engine light comes on half the time when I start my truck, but it goes off when the GPR switches off.
Thank you very much an advance!
Received 3,102 Likes
on
i would change all 8 . motorcraft ZD-11 only.
$10.99 each from Amazon:
$10.59 each from Clay at Riffraff diesel:
Motorcraft Glowplugs ZD-11 - Riffraff Diesel Performance
How many miles on the truck? Original injectors? My brother has a Superduty he purchased with around 235K on the clock when purchased. At around 260K it got so it didn't want to start without being pluged in when the temps dropped to about 40 degrees. The glows and relay tested good, so I was at a loss. At 270 K it started making oil, so a set of good used injectors were installed, and that cured the hard starting under 40 degrees, and the oil making.
Amazon.com: Motorcraft ZD11 Glow Plug: Automotive
Thank you all for your help so far!
on
Do I need a new gasket for the valve covers?
I am not a mechanic by any means, just try to learn what I can from youtube
Thanks for all your help!
Update: replaced the GPs and it didn't fix the problem. However I found that 5 of them were not functioning and autolite brand... So glad I did it. After trying to start it a few times noticed my 8 year old batteries were only providing 10 - 6 volts to the starter. So I went out and replaced them.
Still not starting right. Slow to start but sounds great after it gets going. It also makes an odd deep rumble for about 5 seconds after starting. Not sure if that helps. 11 volts to the starter now.
Any thoughts?
Any thoughts?
