Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1948 - 1956 F1, F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Old 01-21-2015, 06:16 PM
Michael Levy's Avatar
Michael Levy Michael Levy is offline
Michael Levy is starting off with a positive reputation.
Starter on 54 223 Grinding
So the truck was starting and running fine. Tried to start it today and I got a grinding sound. Tried banging on starter with a hammer. Checked charge on battery. From what I can tell, it's either a bendix problem or flywheel problem. Where to start? Should I remove starter and check for wear? Truck has been converted to 12 v, so I don't if the starter is original or was replaced to a 12v unit as I don't know enough about conversions, so if I need parts or a new starter, don't know which starter or starter parts to order.
Old 01-21-2015, 06:54 PM
raytasch's Avatar
raytasch raytasch is offline
Old guy with old toys
raytasch is a splendid one to beholdraytasch is a splendid one to beholdraytasch is a splendid one to beholdraytasch is a splendid one to beholdraytasch is a splendid one to beholdraytasch is a splendid one to beholdraytasch is a splendid one to behold
These starters generally have two issues. Worn brushes and worn bearings. The six volt starters generally survive quite well running on 12 volts. If the bendix is kept reasonably clean, about the only problem they have is a broken spring. Probably time to remove and examine the starter. Who knows what you'll find, perhaps a mouse nest gumming things up. If you have an independent shop that can rebuild it, that may be your best bet. Recent reports of rebuilds costing in the $50. range.
Edit: Check the flywheel gear when you have the starter off.
__________________
Ray
1949 F-4 Built to drive--script bed.
1956 F350 Stock rebuilt script bed
2007 F150 SC. Driven once in a while. 2015 Escape SE EB 1.6 Wife's ride
Government conceived by genius, now operated by fools.
Old 01-22-2015, 07:39 AM
Thank you Ray. I will do that. Of course, later on last evening, It started right up. I read that when certain parts get warn, depending where they line up when the engine stops, it might slip at next start. Worth taking a look.
Old 01-22-2015, 03:28 PM
Sarafina Sarafina is offline
Sarafina is starting off with a positive reputation.
My Bendix Starter is working fine, but sounds like a Dolphin talking for the first two minutes or so. What gives?
Thanks...
Old 01-22-2015, 03:35 PM
abe's Avatar
abe abe is offline
abe has a great reputation on FTE.abe has a great reputation on FTE.abe has a great reputation on FTE.abe has a great reputation on FTE.
Quote:
Thanks...
Maybe you ran over Flipper.....
Seriously, I see this was your first post. Welcome to FTE. We believe this is the best old ford truck forum on the world wide web!
We need to see pics of your truck, some history and what state you are from!
__________________
abe
FTE member since March '98
1954 F-100, bought from Grandpa in 1977 for $200
1970 F-350 flatbed dump, purchased 9/20/12
Old 01-22-2015, 05:58 PM
raytasch's Avatar
Quote:
This is when the flywheel ring gear gets chipped or missing teeth. Depending on where the engine stops, the starter may or may not try to engage the bad area of the gear. Be sure to turn the engine over to inspect each tooth of the mentioned gear. And, of course, check the teeth on the bendix gear.
__________________
Ray
Old 01-22-2015, 06:58 PM
JimG1098's Avatar
JimG1098 JimG1098 is offline
JimG1098 has a good reputation on FTE.JimG1098 has a good reputation on FTE.
Welcome
Agree with what Raytasch said. I just had a new drive unit put on my starter by a great shop. A good shop will be able to tell weather it is 6 or 12V and can readily order parts for most starters. good luck
__________________
USAF 65'--69'
71st FIS F-106
54 F-750 Fire Truck
http://www.ford-trucks.com/forums/12...ire-truck.html
Empire H&L Co.No.1, Nyack FD, 1965-2001
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
