7.3 tach failure HELP PLEASE
Ok been battling all week an put almost 600 bucks into it. Tach will not work until i drive for about 15 min. I have replaced the following parts. alternator, eec relay, trailer tow relay, selinoid, neutral safety switch , throttle positon sensor, tach sensor, cluster for all guages. batteries . Trans is in safe mode until tach starts working please help
Stop throwing money/parts at it and TEST. See post #2; have you checked continuity of the wires from the tach sensor connector to the TCM, under both conditions (tach working / not working)? Have you measure the resistance of the tach sensor when cold, and again after warming up? Something is happening in that 15-minute period, as suggested above, probably temperature-related. It's most likely something you can measure, but swapping parts won't provide that information.
texas7816
08-24-2015 12:28 PM
l'il ol diesel
12-27-2012 11:18 PM
gixxxerrider600
12-29-2007 08:16 PM
