Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1987 - 1996 F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Old 01-21-2015, 09:30 AM
slinginsaws slinginsaws is offline
slinginsaws is starting off with a positive reputation.
carrier bearings and Speedo
So I am trying to get my old girl running better. One area that bothers me is the speedo wiggeling at 55-58 then it stops. starts again @70.
no weird codes so Im thinking it could be a the carrier bearings? I think I have read where this has been a solution for a similar issue. So here is the main question, How hared is it? will it mess with the rear ends jive? I have already blew up a 538 ring and pinion set doing 45 down the beach, and almost took out a Farriar with my Drop hitch.
thanks guys!
__________________
1995 F 250 351w super cab long bed black beautie.
Old 01-21-2015, 09:33 AM
this question is for my DD that is all stock and 155xxx miles. the 538 gears are in my 93 With 40'S. its no longer on the road.
__________________
Old 01-21-2015, 09:49 AM
Crewcabber's Avatar
Crewcabber Crewcabber is offline
Crewcabber is starting off with a positive reputation.
The speedo bouncing is usually caused by the vss being dirty or going out or the psom going bad.
__________________
The Beast cclb 4X4 460 E4OD4" LIFT 35X12.50X16 OBD1
The Red Rocket 1995 EXTRA CAB s/b 2wd 2.3
Comfort Cruiser 2001 Acura MDX Touring
Annoying Orange 1971 Safari Fiberglass buggy
1969 Chevy C20 factory A/C long bed
1933 Chevy Pickup
Old 01-21-2015, 09:54 AM
I Did the VSS and it was fine. I thought that the PSOM was one that just goes out dead like.
__________________
Old 01-21-2015, 10:40 AM
dixie460's Avatar
dixie460 dixie460 is offline
dixie460 has a good reputation on FTE.dixie460 has a good reputation on FTE.
Nope. Like any electronics, the PSOM can give the illusion of being just fine and then spaz out whenever it feels like it. Check the PSOM board for broken solder joints, leaking caps... the usual things you'd look for.
Also... unplug the RABS module can screw with the signal circuit, unplug the RABS and see if the speedo/PSOM behaves right.
__________________
96 F-150 SCSB - 351W - E4OD - Manual 4x4 - MileMarker Hubs - 3.55 Gears - 31x10.50x15 Falken All-Terrains - York 210 Air Compressor - 130A Alternator - Badlands 12K Winch - Dual Thrush Glasspacks - LED Headlights
Old 01-21-2015, 11:40 AM
where and how do you get to the psom?
__________________
Old 01-21-2015, 11:44 AM
dixie460's Avatar
It's on the back of the speedometer inside the instrument cluster. So take the cluster out, take it apart, pull the speedometer out, and the PSOM is on the back of that. Subford has a picture of it I'm sure... but let me go look for one.
__________________
Old 01-21-2015, 11:50 AM
Thanks Dixie, Have you done this before in my 93 the bezel is all torn and cracked. is it tricky to remove it without damage? the 95 is in perfect shape and i really want to keep her that way
__________________
Old 01-21-2015, 12:00 PM
dixie460's Avatar
Okay, no go on the pic search.
Yes I have done it, you have to pry off the plastic trim strips on each side of the bezel. There's screws under there... take 'em out. Then remove the headlight kn0b by using a pick or something. Stick it in the slot on the side, lift the locking tab, pull it straight off.
Unplug the fuel switch, and any other wires going to the bezel controls.
Cluster comes out with 4 screws after that. To take it apart, take off the lens and pull each group of gauges straight out. Speedo comes out last. When you have the speedo in your hands turn it over and you'll see the PSOM board on the back of it. Unplug the ribbon cable and undo the (4?) screws holding it down, and there you go!
__________________
Old 01-21-2015, 12:08 PM
Awsome Dixie Ill give it a shot. hopefully this weekend i can start getting all this squared away.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
