Transfer Case Fluid Requirements
This is the first I've heard of this.
TSB 06-14-4 came out in June 2007:
http://www.aa1car.com/library/ford_tsb_06144.pdf
Now there's a YouTube video in December 2014 telling me that the Mercon V I've been using in the transfer case since I bought the truck (fall of 2007) has been eating away at my at my transfer case turning its innards to Jell-O for over 7 years!!?!?!!?
This is interesting since I was off-roading just a couple of weeks ago and the front end was clawing like a champ and it's never leaked, seeped or wept a drop of moisture.
In my years on FTE I've not come across any transfer case concerns or any failure epidemic since the switch to Mercon V. Is there any truth to the YouTube "Brian"? Have I been blind to this issue? Do I need to go home tonight and drain my transfer case??!?!!?
Quick, somebody hand me a paper bag! I'm starting to hyperventilate!!!!
New to me as well.
I asked for the Transfer Case Fluid at the Parts counter and the guy said "What?". I explained it to him, he did some research, and, BAM! there it was.
Apparently this has been out for a while (since 2012). Ford sent it to all Service Representatives and Shop Manager. It was NOT sent as a TSB, it was sent as a Service Advisory and Vehicle Up-Date to Owners Manuals.
Ford must have had a concern with the failure of a number of units to alter their fluid requirement.
This is what is listed on the SA. Which, I coped from the screen as best I could at the time with people moving all around. It may not be 100% accurate.
Check out Bullet #2.
Transfer case fluid is recommended by Ford Motor Company for use in transfer cases driving front axles on Ford, Lincoln and Mercury AWD/4X4 vehicles
For use in transfer cases where MERCON ATF was previously recommended, discontinue use of MERCON V (incompatibility issue); do not use in AWD vehicles equipped with a transaxle.
Do not use in automatic transmissions, manual transmissions, power take off units (PTU) or fluid couplers.
Do not use in torque on demand transfer cases
Check owner guide and transmission fluid charts for application and latest printings.
It is going to take a few flushes to get all of the Mercon V that's been soaking into the internals for over half a decade...this is what I get for never taking my rig to the shop!
Is there any fluid out there (Mobil 1, Valvoline, etc.) that's interchangeable with Motorcraft Transfer Case Fluid XL-12? Amazon has it for $13/quart and I can only imagine how much the dealership charges.
Google-ing around it seems that there is a fiber clutch on steel backing in the transfer case and that the Mercon V dissolves the glue that holds them together.
Did Mobil 1 change their synthetic ATF ingredients for Mercon V compatibility? Should I be concerned on getting the Mobil 1 out of there or is this more of a Motorcraft Mercon V ATF concern?
Looks like I might have another thing to add to my to-do list...
Looks like I've got another thing to add to my to-do list...
Apparently, from what I'm gathering from the few dealerships that surround us is this is news to them too! How so? They're still using MERCON V. At least the one I visited today and talked with them. Wow!
The Service Manager was writing on the dry erase board when I left in big letter ALL TECHS: DO NOT USE MERCON V IN TRANSFER CASES! USE TRANSFER CASE FLUID - SEE ROBBY IN PARTS FOR CORRECT APPLICATIONS.
I guess a better question is:
Will they cover a vehicle if the Transfer Case fails because they used MERCON V as indicated in the Owners Manual AND their lubrication matrix when they performed the service? This has been out for almost three years! First I've heard of it and I get all the updates.
They have already updated to the third printing for 2015 Owners Manuals for the Trucks - They're into the sixth printing for 6.4 supplements. I Didn't even open that bag of Worms.
One of the guys at the counter was saying they're [Ford] keeping the LV and will be phasing out the V in the next couple years.
This backwards compatible stuff IMO never works for the older vehicles as well as what was originally put in.
I guess I'll just put DEX-III in the TC now on as its the base oil for the Mercon Branded Stuff (minus the additives).
With the exception of the shift rod and clutch disk (the only laterally moving parts, the rest are gear drive). I assume the need for lubrication is minimal but the need for heat dissipation is relevant, especially off road where speeds rarely get above 10 or so MPH.
This is what I have been using in my fleet. It covers everything but synthetic's.
Multi-Vehicle Transmission Fluid - ATF ? Pennzoil
100% agree on the backwards compatibility. Now if only I could find low sulfur diesel around here...
I'll hold off on panicking and keep my Mobil 1 in there (https://mobiloil.com/en/automatic-tr.../synthetic-atf) until I find proof otherwise. NASA uses this stuff so how bad can it be right?
Yep, I swapped my fluids when I bought my truck about 35K ago and put Mercon V in the T case. Damn.... and thought I was doing something.
I have seen this guy on vids for my other cars, seems to have a clue but he's not real clear on what to use.
So Mobile 1 ATF is the call then? Looks like I'll be changing out the Tcase fluid this weekend at 30 degrees!
Thanks to the OP!
Thanks to the OP!
http://www.enterpriseengine.com/prod...parts-diagram/
Kwik would know for sure, though we haven't seen much of him here lately.
Pop
