92 Ford F150, can you change the door buzzer into a chime?
I get very tired of hearing the buzzing sound when my door is open. Is it possible to take out the buzzer and Install the chime? I still need the features it offers or I'd just disconnect it all together.
A 92 is the OBS body style. It has a buzzer instead of the chime that Ford used in everything from the 90's? If so you should be able to R&R it with one from another OBS. Not sure where the chime module is, my truck already had it removed (or it's broken) cause it never makes a sound.
If you can't plug a newer OBS chime in there, then just get one anyway (with a foot or so of it's harness) and wire it up!
Look for a Lincoln Town Car around mid 90's. They have the "dong-dong" sounding chime and its a plug and play last I recall... That's what I put in my truck many years ago.
