Front and/or rear dual shocks
Anyone running dual shocks on the front and back of their F250? I have always liked the look of dual shocks.
I found this. F250 1977.5-1979 Ford 4WD Dual Front Multi Shock Kit | Jack-It, The Suspension Experts
Anyone know how to run dual shocks on the back? Anyone make a kit/brackets for the rear or is it all fabrication?
looks like your in virgin territory there 79? I was hoping you would get some hits. Sounds interesting. In your research, have you ever came across a ford rear axel set up where one shock came off the rear axel spring bolt with the shock stud on one side of the axel and the opposite side of the truck on the other side of the axel?
Funny you brought this back to life!! I just ordered a set of shocks from rough country that are identical to the ones that came with my lift kit. I bought the dual mount brackets from Jegs. Skyjacker DS300 for the front. DS360 for the back. Shocks are already here and the brackets are on the UPS truck. I will post up some pics when I have it done.
