Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1987 - 1996 F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Old 01-20-2015, 06:42 PM
patrickj20's Avatar
patrickj20 patrickj20 is offline
patrickj20 is starting off with a positive reputation.
Squeaking Axle Bearings or U Joints?
So about a month and a half ago my rear axle seals on my 95 f150 4x4 with an 8.8 rear on it went bad. Lately I just haven't had the time to fix it, but I got all my seals, bearings and such. I also got new shoes and a rebuild kit plus the coupling seal.
Now initially there was no squeak from it, that is until recently. I've had to lock the truck in to 4wd a few times with all the snow we've encountered up here in the north recently.
After I started locking it in I've been having a slight squeak. I checked the rear for play on the u joints and didn't seem to find any. Now I did find A LOT on the front driveshaft by the transfer case.
I get the squeak while I'm in 2wd, so while I know I need to do something about that u joint, it couldn't be the one making the noise.
Ideas???
Old 01-21-2015, 12:11 PM
patrickj20's Avatar
Bump! Guys I need advice!
Old 01-21-2015, 12:48 PM
bashby's Avatar
bashby bashby is offline
bashby has a great reputation on FTE.bashby has a great reputation on FTE.bashby has a great reputation on FTE.bashby has a great reputation on FTE.bashby has a great reputation on FTE.
A u joint will squeak when it dries up but won't show any play. You may need to remove the driveshaft and check them
__________________
92 F250 4x4 7.3idi zf5 3.55's Meyer plow
86 F350 2wd C&C Dump 351w C6 4.10s Meyer plow
The rest of my signature changed as to not offend some liberal crybaby.
Similar Threads
Ball Joints Replace...Broken Zerk!! HELP! MikeMcCasland Super Duty & Heavy Duty 13 12-12-2009 09:56 PM
loud squeak/squeal noise coming from rear RShaips 1997 - 2003 F150 0 04-30-2008 10:54 PM
Do u-joints cause squeaking in reverse? Ranger Steve Ranger & B-Series 1 09-06-2006 07:53 PM
Front Hub Bearing bug juice Brakes, Steering, Suspension, Tires, & Wheels 5 05-10-2005 04:23 PM
clutch squeak 88grandmarquis 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 8 06-13-2004 04:35 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
