has anyone tried a programmer with a 92-96 f-series??
i was checking out ways to build power without changing to many mechanical parts, and i was notified that they do make programmers for 92-96 ford efi systems i was wondering if anyone has tried one and knows about the gains that could be had... i know with newer models it makes large improvements in some modular motors 4.6/5.4 but i didn't know if my specific year was to mechanical control instead of computer. i have a 5L 93 efi and it is pretty much factory i know i can get gains from an ecu retune but this is a permanent change and with a programmer it can be adjusted at all times but is not as in depth as the re tune just looking for someone who has used a programmer and if it is worth it.
There's 2 basic types of EEC in this generation of trucks.
EEC-IV, which is what most of these trucks have, can only be modified by installing a chip. You can't use a programmer on it because it don't support flash programming. This EEC is only used with OBD1 systems.
EEC-V, only used in 96 F-150's and some California F-250/350's, CAN be flashed using a programmer. This EEC is only used with OBD2 systems.
Not sure what you think the difference is between a programmer and a tune but there ain't one that I'm aware of. All a programmer (or any tune) does is write different values for certain parameters/variables into the EEC's memory. For example, it might change the engine rev limiter from 5500 RPM to 6200 RPM by writing "6200" into a certain location in memory that the EEC looks at to know what the max allowable engine RPM should be.
Now, there's also these goodies that you might want to look into:
https://www.moates.net/quarterhorse-...rds-p-199.html
http://www.tweecer.com/
Those allow you to plug in and adjust things to your heart's content but in a more advanced way than just going thru the menu's on a handheld programmer.
ok very helpful thnx i was just wondering bout this because i have a few buddies with similar year dodges that run edge and bully dog chips but i haven't seen any fords with any similar tech but i have heard bout it. i was just curious as to the gains and whether they are worth there price
Long story short with these gas engine trucks of this era: there is not much left on engine tune table. You need some serious intake, exhaust manifold and cylinder head work to gain anything. A simple programmer or custom tune with stock parts will gain you almost nothing other than a lighter wallet.
on
The only time you get big power gains with a chip or tuner is when the motor has a turbo on it, otherwise the electronic mods don't really do much. The reason for this is simple, the EFI system is already getting as much power from the motor as it is capable of generating, and to get significantly more power something mechanical has to be changed. I guess if somebody disagrees with this then the best explanation I can come up with is that their idea of "big gains" differs a lot from what I consider to be big gains.
Even going to a full standalone totally programmable EFI system on a stock OBS truck isn't going to yield you any significant power gains by itself. You need changes like bolt-ons for more power - and counterintuitively, more power can actually yield more fuel efficiency if you do it right.
The only naturally aspirated stock vehicles where a programmer, piggyback ECU (like the TwEECer) or standalone ECU will get you "big gains" in power or fuel economy is where the manufacturer is known to have used a substandard computer, had a design flaw such as 'always runs in open loop because there is no O2 sensor', was incompetent at creating the fuel map and other code, or had some sort of artificial limitation for legal or liability reasons. None of these apply to the OBS EEC-IV trucks.
on
You might ask well why didn't the manufacturer put more ignition advance in from the beginning, the answer is they put as much in a the engine would tolerate under various conditions. Sure driving around empty a truck my be able to handle 2-4 more degrees advance but hitch 5000lbs behind it won't tolerate any additional advance.
Right, the only reason I would want to mess with my truck is because I HATE how early she locks up the converter going into 3rd gear. And also how long it takes to shift, but that could be a hydraulic thing too (needs a shift kit so the clutch apply servo's fill faster).
More power ain't happening without the hardware to back it up. And for me that means ditching the crappy E7 heads... I will wait for rebuild time to do that. They've been on there for 260k miles so far, might as well let them finish out this round of the engine's life.
DIYMechanic
58
11-23-2013 11:28 AM
Knoxentucky
03-29-2010 12:15 PM
