Go Back   Ford Truck Enthusiasts Forums > Diesel > 6.7L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
6.7L Power Stroke Diesel 2011-2015 Ford Powerstroke 6.7 L turbo diesel engine
Driver's Side Sagging
Old 01-19-2015, 09:51 PM
2015F350 2015F350 is offline
2015F350 is gaining momentum as a positive member of FTE.
Click the image to open in full size.
Front Driver's Side
Front Passenger Side
Anyone with a 2015 F350 have this issue. I parked the truck in the garage today to do some detail cleaning, and noticed it sagging on the driver's side. Seems like the front coil springs are weak on the driver's side. I called the dealer and they told me to bring it in. They are going to look at it tomorrow. Look at the images, it's almost an inch difference. Truck has never been off-road yet, only has 4000 miles. At first I thought it was a low tire but I checked both tires have 70 PSI. Then I thought it was the floor so I measured from the tire to the fender and got the same results.
__________________
Robert
2015 F350 SRW LB Lariat, 6.7 PS Diesel, Included Packages: Fx4, Lariat Ultimate, Chrome, Tow, 11500# Suspension, 20" Wheels, Factory 18K Reese Hitch
Old 01-19-2015, 10:01 PM
Wrighton's Avatar
Wrighton Wrighton is offline
Wrighton is starting off with a positive reputation.
I have the driver side sag as well with full tank 35 gal of fuel, I don't think its spring sag more like weight distribution with the fuel tank.
__________________
2012 F350 6.7 CC 172" WB XLT Premium Package
FX4, 11500# GVWR Camper Package. Silver Metallic
2012 Keystone Montana 36' 5th Wheel
Old 01-19-2015, 10:03 PM
Why would that affect the front spring and not the rear. The tank is under the bed.
__________________
Robert
Old 01-19-2015, 10:23 PM
Wrighton's Avatar
Quote:
I have seen about 1/2" difference also between the rear driver side and passenger side measuring at the overload spring to the stop, again I measured with a full tank. There have also been posts on the same issue. Yes fuel tank is under the bed but it's on the driver side of the frame. Hey, I'm with you on this issue, my 97 f350 didn't sag like my 2012.
__________________
Old 01-20-2015, 03:38 AM
Dakster's Avatar
Dakster Dakster is offline
Dakster has much to be proud ofDakster has much to be proud ofDakster has much to be proud ofDakster has much to be proud ofDakster has much to be proud ofDakster has much to be proud ofDakster has much to be proud ofDakster has much to be proud ofDakster has much to be proud of
My 2015 also rides a whole lot nicer than a new 1997 did too...
__________________
2015 F350 6.7L CC LB 4x4, Platinum, Black on Black. Steering wheel heater, Supplemental and Rear Seat Heaters, Moonroof, Ford Factory wheel liners, rubber floor mats. Extang tri-fold Cover, Rubber Bed Mat, extend-a-bed.
Old 01-20-2015, 05:07 AM
roadrunner01 roadrunner01 is offline
roadrunner01 is gaining momentum as a positive member of FTE.roadrunner01 is gaining momentum as a positive member of FTE.
This is something that has been talked about for years. Through weight distribution the drivers side is dedicated to be noticeably lower on level surfaces to account for the crown in road surfaces. Almost all roads have crown in them to allow water to drain off to the berm, so when you drive your superduty you don't notice it quite so much with the drivers side a bit lower.
Old 01-20-2015, 05:58 AM
ruschejj's Avatar
ruschejj ruschejj is offline
ruschejj has a brilliant futureruschejj has a brilliant futureruschejj has a brilliant futureruschejj has a brilliant futureruschejj has a brilliant futureruschejj has a brilliant futureruschejj has a brilliant futureruschejj has a brilliant futureruschejj has a brilliant futureruschejj has a brilliant futureruschejj has a brilliant future
Joel Rusche Joel Rusche Joel Rusche
Have someone sit in the passenger seat and measure again.
Stand on the rear bumper, jump up and down for a few seconds and measure again.
I would also check again with 1/2 tank of fuel.
Just some ideas....
__________________
2015 F350 CC KR SRW LB 4x4, 3.55ELD, ordered 9/4/14, home 10/24/14. Factory 5th wheel set up, VIAIR #10009 kit, train horns, ride-rite air bags, CB, Strobe lights, BedRug, BakFlipG2, TransferFlow in-bed 50gal tank, 2 Kicker 10" subs, Polk 1" tweeters, tinted front windows, Tuxedo Black Monotone option
Old 01-20-2015, 06:55 AM
Lastwagen's Avatar
Lastwagen Lastwagen is offline
Lastwagen is starting off with a positive reputation.
Mine sags too. About 1/2" but still noticeable in a parking lot. I'm sure more when I'm in the truck. I'd like to shim it to level it. Any suggestions on front or rear shims?
__________________
DW
2015 F250 Lariat Platinum White FX4 6.7 CC BD 7/25/14
2008 C6 Corvette LT3 Z51 Victory Red
"You can easily judge the character of a man by how he treats those who can do nothing for him."
~ James D. Miles
Old 01-20-2015, 08:25 AM
djousma djousma is offline
djousma has a good reputation on FTE.djousma has a good reputation on FTE.
Quote:
Ford actually makes a shim for this very purpose. Had to have one installed on my 2005 for this very reason. It was installed on the rear axle. Was successful in getting it covered by warranty after a little haggling. Seems even though it was visibly noticeable, it wasnt "out of tolerance", in their words.
__________________
Dave
2011 F350 Lariat 4x4 FX4 SRW CC SB 6.7 Sterling Gray Metallic
SOLD:2005 F350 XLT 4x4 FX4 SRW SC SB 6.0 PSD/TS Med. Wedgewood Blue, Dual Alternators, Tow Command, Bypass Coolant filtration.
Old 01-20-2015, 11:55 AM
Lastwagen's Avatar
Quote:
I'll check with the dealer. I'm thinking that if it's shimmed in the rear there shouldn't be any alignment issues. Thanks for the reply.
__________________
DW
~ James D. Miles
Old 01-20-2015, 01:27 PM
Blapensee's Avatar
Blapensee Blapensee is offline
Blapensee has a very good reputation on FTE.Blapensee has a very good reputation on FTE.Blapensee has a very good reputation on FTE.Blapensee has a very good reputation on FTE.
mine sags also. swapping the front springs won't change anything. its pretty annoying to me but its just they way they are..
__________________
2012 F350 DRW
6" Fabtech 4 link 35/12.50 Toyo M/T's,2inch rear spacers, air dog 2, H&S, PMF traction bar blocks, firestone airbags, BD Diesel turbo timer, 64mm streetmax, all LEDs, Turbosmart BOV
Old 01-20-2015, 04:47 PM
Tofan's Avatar
Tofan Tofan is offline
Tofan has a great reputation on FTE.Tofan has a great reputation on FTE.Tofan has a great reputation on FTE.Tofan has a great reputation on FTE.Tofan has a great reputation on FTE.Tofan has a great reputation on FTE.
There is a procedure in the service manual to correct this problem!! I only have the one for the 08-10 trucks but I can't imagine its much different. I'll post it later when I get home.
Old 01-20-2015, 09:10 PM
Well after a trip to the dealer, which was a waste of time and fuel, they state it is within tolerance levels. They decline to do anything since they state it can be as much as 5/8" difference according to the Ford dealer. They do acknowledge that it is sagging but they said it is at an acceptable level. I guess I'm going to have to live with it, or shim it myself if I want it right.
__________________
Robert
Old 01-21-2015, 10:28 AM
you can ask them to appeal to the regional guy, and see wht happens. Dealer did the same thing to me. Regional guy approved it. Shouldnt have to pay to fix it, but now that you know, its gonna bug you forever. Parts cannot be that expensive. The shim is about 1/2" thick 4"x4"(approx) square block of metal that sits between the axle and spring pack. Pretty sure the kit comes with longer hardware to bolt it all back together too.
I dont have the truck that needed it anymore, so my recollection could be a bit foggy.
__________________
Dave
Old 01-22-2015, 06:30 AM
U235Fishin' U235Fishin' is offline
U235Fishin' has a good reputation on FTE.U235Fishin' has a good reputation on FTE.
I am a chronologically enhanced sailor ..... I'm used to dealing with a list.
__________________
2012 F250 XLT, 6.7L, 4x4, CCSB, 3.31 ELD, 18" wheels, Edge Insight CTS, SnugTop cab high shell, Rancho RS9000XL shocks, Air Lift bags & WirelessOne compressor, 50 gallon Titan fuel tank, 25Y Arctic Fox TT
Similar Threads
Leer Cap / camper shell With Tool Box's R1racer All Other Items for Sale 2 03-11-2015 09:24 AM
2015 White Platinum 69cj 6.7L Power Stroke Diesel 20 02-23-2015 11:27 PM
2003 2wd 6.0 Excursion 2wdDezlX Excursion - King of SUVs 19 02-15-2015 06:25 PM
I need a shock mount plate!! El Guapo 48 1948 - 1956 F1, F100 & Larger F-Series Trucks 0 01-21-2015 03:30 PM
What head is this? 351W engine supposedly Island Time Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 4 09-01-2014 01:22 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
