1976 F150 - Need Help!
Also, this is how your warranty plate decodes:
F15BEB29386
133 E F150 MR4 F 143
06050 1976 14
F15 = F150 2WD pickup
B = 300 cu in 6 cylinder 1 bbl. engine
E = Mahwah Assembly Plant
B29386 = 1976 consecutive serial number
WB 133 = 133" wheel base
Color E = Jade metallic
Model F150 = F150 2WD pickup 6050 lb GVW
Body MR4 = (MR) Jade vinyl and Jade cloth interior (4) Styleside pickup bed
Trans F = Warner T18 4 spd manual transmission
Axle 143 = This is the first time I've come across this code. Usually the code for the rear axle is two digits and the third digit describes the front axle and equipment. The way this decodes is (14) Ford 9" non-locking, 3,750 lb capacity (3) 6,000 lb front axle w/o power steering. If your truck has power steering check to see if the "3" is actually a "J", this is the most common digit and signifies a standard front axle with power steering.
A 6000 lb front axle would be super heavy duty in a half ton.
GVW 6050 = 6,050 lb gross vehicle weight
1976 = 1976 model year
DSO 14 = Pittsburgh District Sales Office
F15BEB29386
06050 1976 14
terceslil
24
03-09-2009 07:43 AM
rustygreen76ford
04-29-2003 10:44 PM
