7.3 MBRP exhaust
7.3 MBRP exhaust
This past weekend I received my 4" mbrp 302 stainless steel turbo back exhaust. Today my mechanic went to install it and found that it did not not fit. He called mbrp and they said that cutting is necessary to fit a super cab short bed. He then called a local custom exhaust shop and they can only cut 3" pipe. I am left completely puzzled. Anybody have an idea on how to go about cutting the pipe? Can a bandsaw do the job? Any ideas would be greatly appreciated as the truck is not drivable now.
Received 3,099 Likes
on
air powered cut off wheel...its what I used 4 months ago when i did mine.
Depends on cab length, you don't always have to cut, sometimes you can just remove one of the pipes. When you install it is pretty clear where to cut on the mid-pipe.
I have a crew cab long bed and I cut mine in between the axle and the cab... I had also ordered a second piece of 4" stainless pipe 36" long and was able to mix and match to cut less off
robs01f250
21
10-05-2011 10:12 PM
DieselBeast01
20
12-20-2008 10:39 PM
Powerstrokedlariat
11-17-2004 08:52 PM
