Coolant Leak Diagnosis
Last night I filled it to the min line (cold) and it appears to have stayed at that level.
I'll drive 12 miles to work and then check after 3 or 4 hours to see if it holds to to the min line.
I assume that if it's leaking I'll see some coolant in the little lip - is that assumption correct?
I'm willing to try that. How far below the min line (cold) would still be considered safe?
I recently flushed my entire coolant system and put in red ELC. In addition, replaced the water pump, upper and lower hoses, thermostat and housing and since then have had to top my coolant off 4 times. I think it is has settled now and I contributed the topping off to the 8.5 gallons of coolant in the system. Think about how much fluid that is and putting in a few ounces here and there while settling is not a big deal.
My level has since settled and I do check it regularly, just like everything else since the truck is not a daily driver.
The paper towel stayed bone dry.
It's looking like those who said to be patient and let it settle in for a many as 100 or 200 miles are going to be proven correct. For the first time in about 10-15 trips (~120 miles) the coolant level appears to be stabilizing. I made a 24 mile trip without significant change in the coolant level. Every other time out I had very noticeable drop.
No need to build one if you live near Oreillys, check out post #4 in my recent thread:
https://www.ford-trucks.com/forums/1...appearing.html
Gettysburg150
10-28-2014 03:04 PM
dubcnea
04-08-2014 10:49 AM
