Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1961 - 1966 F-100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Brake Light Switch
Old 01-19-2015, 12:45 PM
Shadowrider123 Shadowrider123 is offline
Shadowrider123 is starting off with a positive reputation.
Brake Light Switch
Twice in the past couple days I have gone out and found my brake lights on.
If I pump the pedal a couple times the lights go off and stay off.
If that indicating a pressure loss in the brake system or a bad brake light switch?
__________________
1964 F100 292/AT (Mine)
2012 Dodge Caliber (Hers, under protest)
1994 Mustang GT Droptop 49,000 miles (Hers)
Old 01-19-2015, 02:05 PM
gangstakr's Avatar
gangstakr gangstakr is offline
gangstakr is a splendid one to beholdgangstakr is a splendid one to beholdgangstakr is a splendid one to beholdgangstakr is a splendid one to beholdgangstakr is a splendid one to beholdgangstakr is a splendid one to beholdgangstakr is a splendid one to beholdgangstakr is a splendid one to behold
Instead of pushing on the brake pedal lift up. If light goes out, might be just an adjustment at the brake pedal. See if you have a plunger type switch at pedal if so just an adjustment might be all that's needed.
__________________
"Kingdom Animal Dentist"
“The object of war is not to die for your country but to make the other guy die for his.”
Staying low for now
64 lowered longbed
Robert
Old 01-20-2015, 08:16 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by Shadowrider123 View Post
Twice in the past couple days I have gone out and found my brake lights on. If I pump the pedal a couple times the lights go off and stay off.
Replace the switch.
C1AZ-13480-A (replaced 0A-13480) .. Stop Lamp Switch (Motorcraft SW-24) / Available from Ford & auto parts stores.
Applications: Myriad 1940/66 FoMoCo vehicles.
This switch is pressure activated and is notorious for getting gummed up with dirty brake fluid. It's located at the front of the master cylinder.
There's no way to adjust the brake pedal and the plunger type switch (located on the pedal itself) was introduced in 1967. 1967 is one year only, 1968/72's use a different switch.
__________________
Bill / Retired Ford Parts Manager / SoCal Chapter Member / Part number research: 1928/2001 trucks & 1928/89 passenger cars.
2013 Escape FWD 2.0L Eco-Boost
Old 01-20-2015, 08:33 PM
gangstakr's Avatar
Sorry I have a 64 and I forget about a lot of things that were done on my truck vs. stock. for instance my brake switch is adjustable.
Name:  brake switch 003.jpg
__________________
Staying low for now
64 lowered longbed
Robert
Old 03-03-2015, 12:55 PM
daveengelson daveengelson is offline
daveengelson has a good reputation on FTE.daveengelson has a good reputation on FTE.daveengelson has a good reputation on FTE.
Sorry, this thread is response to question I posted recently. Robert, thank you for the pic, going to look under the dash to determine which set up will best meets my application, not sure if the clutch pedal will come into play.
__________________
'problem with engaging in useless activity is never knowing when your done'
Dave
65F100, 302ci, T18, swb, flareside,front disc. PS, Duraspark Ign.(Daily Driver)
65F100, 390ci, 3sp.OD, lwb, styleside, front disc., Duraspark Ign.
Similar Threads
2006 F-150 Brake Light Stays on Stevenmed 2004 - 2008 F150 11 03-30-2015 02:41 PM
brake light driver side only works with trucke off? fellupahill Electrical Systems/Wiring 4 07-05-2013 09:02 PM
BOO? diz71266 1968-2013 Full Size Vans 2 05-15-2011 12:57 PM
No brake lights on my 86 F150 Dustin_86 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 12-02-2006 05:40 PM
1996 Ford F250 - Brake Warning Light FordBear 1994.5 - 1997 7.3L Power Stroke Diesel 3 11-11-2003 04:08 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
