6.2L V8 Discuss the 6.2L V8
pics of modified exhaust on lifted super duty?
Old 01-19-2015, 10:23 AM
96grimreaper's Avatar
96grimreaper
96grimreaper is offline
Considering going with a 4.5" or maybe a 6" lift on 37's. I know guys have either modified the exhaust or had a custom front drive shaft built to avoid the rubbing. Not going to have a new drive shaft built though.
If I do go with the lift I'd like to be able to show my exhaust guy what needs to be done. Anyone have pics?
Old 01-24-2015, 06:09 PM
projectnitemare's Avatar
projectnitemare
projectnitemare is offline
Pretty easy to accomplish really. Pull the big muffler which is the y-pipe. There will be a welded bracket between the 2 head pipes. Cut that bracket out. Now you can loosen the driver side pipe and turn it away from the driveshaft. Weld a new bracket in place. You can now either toss the big muffler, install a y-pipe (I used a flowmaster y-pipe from Jegs) and connect the rest of the exhaust; or put the muffler back which may need some modification to get back in place. Too much snow on the ground for me to take pictures, pretty easy to figure out though.
Old 01-24-2015, 10:45 PM
96grimreaper
Thank you. I guess I need to crawl under it again to get a better idea. Wasn't sure how much extra clearance would be needed after the lift.
Old 01-25-2015, 07:40 AM
projectnitemare
Mine barely rubbed at all. The issue is when the suspension compresses the driveshaft will be pulled toward the exhaust. I turned the pipe until I had just enough room to pull the transmission pan if needed. You may be able to refuse the trash can size muffler but I wanted more noise so I tossed it.
Old 02-21-2015, 09:14 AM
dave7200's Avatar
dave7200
dave7200 is offline
The best way is to get an adjustable track bar and move the front axle over about a half inch. It takes care of the problem and the axle is to far the other way from factory anyway. To verify measure how much the tire sticks out of the wheel well on each side.
Old 02-21-2015, 03:43 PM
projectnitemare
An alignment will verify whether you need the adjustable track bar or not. Whether you need a new track bar or not get the alignment right. That's the important part, it's safety. If the driveshaft still rubs then the exhaust needs modified.
fishbones182
Offroad & 4x4
02-27-2016 08:17 AM
ArlyDude
10-18-2012 10:15 AM
CropDusterMan
05-15-2011 12:48 PM
syjl
18
09-26-2007 11:28 AM
Quick Reply: pics of modified exhaust on lifted super duty?
