1979 f250 h clip keeps falling out
I have a 1979 f250 4x4 3/4 ton that the h clip and spring keeps falling out of the break caliper which let's the caliper move all over inside the rim....I've bought a new clip and bolt and it still keeps falling out as I'm driving....how do I fix this....what is the secret to keeping it in place...please help!!!
Are you installing the H bar (caliper support) the correct way/direction? So it has two 1/2 round notches on the bottom and the bolt (key retaining screw) with a built on washer will be in one of those notches? Are you sure you are getting the caliper installed with it under the top lip 1st of the caliper housing? Hooks under the top lip/edge then rotates down, than tap in the H bar?
That's exactly how I'm doing it....but its poping over the screw and falling out....I just bought the truck and it had a makeshift h bar and spring in that the last owner had used to fix it so I bought a brand new one with a new screw....I'm just wondering if I'm missing something else and not seeing it....the screw is tight against the h bar when I put it together and somehow its still coming out
460 FORD MAN
05-05-2013 12:32 PM
martin8459
15
07-23-2009 03:01 PM
Drac
03-03-2008 02:14 PM
