Leaking tank..
on
One common issue is corrosion of the top plate or hard lines of the fuel sending unit, and the tanks also tend to rust at the seams first but that usually produces a leak at anything over 1/2 tank. The tank is only held up with 2 straps so it's a bit messy but not to hard to drop when it's empty, but some find it easier to remove the bed to access it.
Changing fuel pumps/senders is easier, IMO, by lifting the bed. The tank has to come out the bottom for replacement though.
I guess if you're not accustomed to raising up the bed you might have reservations. I've changed enough pumps to be able to do it pretty quickly. Chances are much greater that the tank is leaking though and as I said, it has to come out from below. Crawl under and find the leak before proceeding.
ReFlectiveMan
01-05-2011 09:14 AM
Sharky146
09-30-2010 03:58 PM
randle_ford
08-09-2005 09:05 PM
