Building a fuel tank to go inside an oak whiskey keg
I'm building a custom tank to install inside an oak whiskey barrel I have. If everything works as planned it will be mounted in the box and secured to the existing cross member behind the cab. Just thought I'd post a couple of pics for fun and see if anyone has any ideas or thoughts.
31 1/2 long x 15 1/2 wide. If it was completly full it should hold around 21.5 imperial gallons or 26 US gallons. It's being made to cruise and not have to stop at every gas station on route.
You can see the tappings for the pickup tube, the fill connection, the rollover vent and for the sender.
That would be an ice auger for ice fishing in the top RH corner. Was out with it today and got into some nice perch. Ice is already 22" thick.
Here's the barrel I hope to use.
There's going to be 2 baffles inside to keep things from sloshing to bad.
I am. I just ordered 2 quarts of Red Kote. They should be here in a couple of days. I looked at the por15 system and a couple other sealers but was nervous with some of the reviews. The Red Kote reviews were more positive and I like that it remains a flexible material. Plus it is designed for gas and diesel.
I tried sanding that barrel down. I've tried a sand blaster, 80 grit, 40 grit and a file. That crap is tough. I haven't made it to the raw wood yet. I think I will clean up the rings and just seal the wood the color it is. Unless some of you have any ideas.
Cool build on the tank. Where did all the whiskey go? Just bought a Jiffy 10 inch and need a high speed screw. Folks been driving on the ice for a month down here. How are you going to fasten the double barrel to the truck? An oak 4x4 and a bandsaw might do the trick.
I did make some more progress today. The last baffle and the tank end are welded in so the metal tank is done.
I got the one end of the barrel cut out so the tank fits. I had to screw the cut ends together to keep the ends rigid.
This is what will support the ends of the tank. The exposed ends will be covered with 2 circles of the aluminium checker plate I'm using for the floor.
Oh ya, most of the whiskey was gone but I managed to roll a good 3 gallons of swish out of it before I had to let it dry out. That's Canadian gallons and it tastes pretty smooth. I keep it in the shop in a blue water jug for special visitors.
Bourbon barrels can only be used one time for bourbon. They use to be easily available but now wineries and breweries are using them for special wines and beers. I had two Woodford Reserve barrels we used for rain water. The first few times they were filled you could still smell the bourbon. They only cost me $40 each about ten years ago.
Barrels used to be available here to at the distillery but they stopped selling to the public. A few people who work there say its to stop people from making swish. All I know is they are getting hard to find and getting expensive.
Does anyone have any suggestions on what to seal the barrel with. I'm leary of any type of varnish because the barrel will expand and contract I'm thinking.
