Oil pressure sender leaking
I have a 2006 6.0 and recently I rebuilt the turbo and did the fix for the injector stiction. Now I have blown three oil pressure sending units. I also replaced the low pressure relief valve after the second sensor.
Tomorrow I'm going to try to remove the sender and install a oil gauge and see what type of pressure is.
Any info will be greatly appreciated.
Thanks
Thanks
Thanks
Thanks
over pressure or not.
What brand of sender are you having problems with and did they come with
the O-ring or did you reuse the old one?
Sean
I put the oil gauge where the oil pressure sending unit goes today and I got 34 psi at 700 RPMs.
In the process of doing this I had broke the radiator and had to replace it. I sure had a lovely day. Also Pep Boys sells the tool for the radiator transmissions lines.
Anyone have any ideas what is causing my high oil pressure?
Thanks
Thanks
I have some confusion here. Where are you getting your reading?
The dash gauge sensor [one wire sensor behind the filter houseing] At the test port on the filter houseing or the ICP?
Low pressure pump oil is regulated at 45 PSI min. With a bad regulator I have sometimes seen as high as 70 to 75 psi. and should be the same for the switch.
ICP should be no less than 500 PSI to start. PCM likes to see 650.
So guys what are we testing here?
