Oil Leak at Base of Dipstick Tube/1989-460
Need some input here.
My 1989 shop manual does not show an o-ring at the base of the dipstick tube.
When I got the truck, there was silicone caulk around the front timing cover-to-oil-pan and around the entry of the dipstick tube into the oil pan.
Oil pan and timing cover are redone and repainted, but I haven't yet been able to get this last leak stopped yet.
The dipstick tube looks like there are two rings stamped into the metal that could retain an o-ring.
Oh, and Ford Parts said they don't show a number for it either.
There is a one post thread in the archives where the poster found an o-ring at Ford, apparently to solve a similar issue, and posted a part number.
Ford Parts said it was a good number and that you had to buy ten and the cost was pretty astounding.
Matched up an o-ring at NAPA, but I'm still leaking at the dipstick tube entry into the oil pan.
What's the deal?
What's the deal?
Thanks
Did you have to use Ford O-rings, (the ones they apparently do not list)?
Thinking the O.E. rings may have a different O.D.
Scroll to the bottom of this page and under "similar threads" titled "460 oil pan dipstick leak fix" by "33homerdoodle" is a thread with a picture and part number.
I have a related thread in the 1987-96 forum.
I did get a response there that a new factory tube came with an o-ring, but even that was a question that Ford Parts couldn't answer.
So would the blow-by be caused by a worn head. And I would probably have to do a compression test. Where would I connect to for that
on
Yes = clean out/replace
No = you have a bigger problem like the aforementioned blow by.
Make sure you are not overfull on oil also, as this is nearly as bad as being too low.
TobaccoBarn460
01-18-2015 11:10 PM
tstorm
03-20-2011 11:07 AM
John311t
04-27-2008 05:02 PM
Sailfish83
05-25-2006 02:34 PM
