LMC Floor mat - Ford Truck Enthusiasts Forums
LMC Floor mat
Old 01-17-2015, 10:39 AM
Mike54 Mike54 is offline
Mike54 is starting off with a positive reputation.
LMC Floor mat
This is the floor mat I got from LMC Truck. It's been laying out like that for over a week and as you can see it's still got a pretty good wrinkle in the passenger side. Is it possible to make this thing lay flat on the cab floor? I'm considering returning it. I just don't know if I should ask for a refund or another mat.
I called LMC and they said they've never had this problem before and I should send them a pic. I did that and got no reply.
This is supposed to be a fun hobby. Stuff like this has a way of making it not so much.
Old 01-17-2015, 10:48 AM
resonateur's Avatar
resonateur resonateur is offline
resonateur is gaining momentum as a positive member of FTE.
In the summertime, laying it out might do the trick, but not in cool weather. You could try a hair dryer, heat gun or propane heater to soften it up an lay it out. The problem is probably not with the mat, but the way it's stored and shipped.
Old 01-17-2015, 05:44 PM
Quote:
Well I am in California and the weather's been pretty much in the 50's and 60's so I guess that cold for us. I could try giving it some heat and see what happens. I'm hoping to hear from someone who's installed one before and could tell me what their experience was.
Old 01-17-2015, 09:22 PM
TxStang2010 TxStang2010 is offline
TxStang2010 is gaining momentum as a positive member of FTE.
lay it in the truck and use a hair dryer to warm it up , a heat gun may get too hot and scorch it . with it in the truck and warming it up it allows it to fall into the floorboards naturally
Old 01-19-2015, 07:39 PM
ige1963 ige1963 is offline
ige1963 is starting off with a positive reputation.
I got one from them for my '63 and installed it when it was hot outside (and in the shop) I laid it out in the sun and it was fine - contoured to the floor very nicely - hot weather is/was the key. Btw - mine looked a lot like yours when I got it and I didn't think it would go in
Old 01-20-2015, 12:20 PM
Quote:
Thanks that's good information. Direct experience means a lot.
Old 09-07-2015, 12:50 PM
Macs1964F100's Avatar
Macs1964F100 Macs1964F100 is offline
Macs1964F100 is starting off with a positive reputation.
Did you get the rubber or MIP mat from LMC? The MIP sounds a little more durable and a has a jute backing.
Old 09-07-2015, 09:36 PM
Flor mat
Quote:
I got the rubber one without the backing - it fit nicely with just a little trimming. It was stiff and unmanageable until laid out in the sun to warm up. I'm satisfied with it
Old 09-08-2015, 11:31 AM
theastronaut's Avatar
theastronaut theastronaut is offline
theastronaut is gaining momentum as a positive member of FTE.theastronaut is gaining momentum as a positive member of FTE.
Put it in the truck and use a heat gun to let the wrinkles relax. This was an ACC mat after it was in a few days, then gone over with a heat gun.
Replacing Rubber Floor Mats Hogtrapper 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 23 08-16-2015 01:33 PM
High/Low Floor Tunnel Question fitzmotor 1973 - 1979 F-100 & Larger F-Series Trucks 4 07-26-2014 06:35 PM
Need a floor mat for 1960 F350 Marks9mm 1957 - 1960 F100 & Larger F-Series Trucks 3 07-04-2014 08:40 PM
LMC 1/8 thick Polyvinyl floor mats EP145 1973 - 1979 F-100 & Larger F-Series Trucks 4 03-26-2014 08:41 AM
Cab floor mats: vinyl or rubber? tjw11235 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 10 03-21-2011 08:55 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
