I have a 1999 f250 that runs and drives great but the only issue I have is when I baby the gas pedal it stalls a little and when I give it more gas it's fine or if. I'm going 50mph then let off gas and then baby the pedal it's stalls a little,thanks
Sounds like the tps.
Look inside the throttle body for soot or oil, and clean .
Also check the iac , idle air control, it has many more functions than just controlling idle.
