Needed parts & information.....
Hi everybody,
I am restoring 1964 f100 custom longbed truck, and I need some help if y'all may have the parts. I need the following:
a 5 terminal 1 speed wiper switch with the wiring connector on the back.
i have the '64 ford f100 shop manual, but, I need a true dash wiring schematic that shows all wiring in cab of truck (dash, heater, wiper).
I hope y'all can help me,
Thanks,
Doc64
Thanks,
Doc64
Note: There were two different single speed wiper switches used on 1964 F100's. The following is the correct switch, the wrong switch is listed below.
I'm passing along this info so you won't get a switch from a junkyard...only to find out once it's been removed...that it's the wrong one.
C3TZ-17A553-G (replaced C3TZ-17A553-C) .. Single Speed Wiper Switch-5 terminals-Use with Ford wiper motor / Marked: C3TB-17A553-C or G (Motorcraft SW-722) / Obsolete
Applications: 1963/66 F100/600.
No Ford dealer or obsolete parts vendor has either of these two part numbers.
C3UZ-17A553-D .. Single Speed Wiper Switch-3 terminals-Use with Bosch wiper motor / Obsolete
Applications: 1963/64 F100/600 & 1963/67 Econoline.
The plug (wiring connector) was only furnished with the dash wiring harness.
First and Foremost-Welcome to FTE. Found this site reportedly of the 64 Ford pickup??
1964 F100 - F750 Wiring Diagrams - The Old Car Manual Project
If you find the link to cumbersome I purchased a paperback wiring manual from Jim Osborn Reproductions, Inc. for the 65 for $7, some of the Ford part supplier's carry them. I found it very helpful tracing wiring gremlins.
Again, welcome to FTE, looking forward to your input and post pic's if and when you can.
Chiefdan
11-10-2018 10:33 AM
Kirkb1
10-20-2017 11:58 AM
tonkaman3
32
08-22-2016 08:38 PM
Coldstoli
15
05-05-2015 08:55 PM
