8.8 explorer rear end
Received 4,113 Likes
on
on
on
I actually used a Lincoln mark vii 8.8 rearend on mine I used the whole drivetrain.
I used the e brake lines, swaybar and mounts even the driveshaft fit.
on an explorer 8.8 I would use all that, heck I would even cut off the existing perches and weld them back on where I wanted them. I would reuse the u bolts and u bolt plate also. I would even take the brake flex line if it looked good lol.
they should pretty much throw in that stuff, except maybe the drive line.
sometimes it easier to use what you got rather than order and find stuff.
I don't think you would need 3" spacer's. Maybe 1 1/2 " per side. It all depends on what rim backspacing you have.
#29
When I pulled my explorer rear from the pick and pull yard, I also took the ubolts and mounts from the donor. I know I will need to get new, correct size perches, but I was thinking of reusing the mounts to mount my rear end in the F1. I seen a posting from another build were the guy cut a section out of the explorer mounts lengthwise then welded back together to account for the different spring width size (explorer spring width and stock F1 spring). He also cut off the shock mount and welded to the axle to keep the rear shocks in the stock location. I'm not sure how good of an option this is.... This is a cheap option (repurpose what I have) but I don't know how well it will work out. Has anybody else attempted this?
#30
I have seen a few options for shocks. Some people use the stock lower mount bolt and weld it to the new plate then retain the stock location. I have seen complete custom mounts with new tabs welded to the tube and a new cross bar welded at the frame to change shock location for a further outboard setup (the further out the more it helps, usually)
