Where should i send my IDM to?
Old 01-17-2015, 10:27 AM
MI02SVT's Avatar
MI02SVT
MI02SVT is offline
Buddy of mine has same exact problem cold idles fine after it warms up and drives it when it's idling it knocks but not while driving he has 30k less on his than mine and excessive blow by mine has none told him to get the compression checked
Old 01-17-2015, 02:52 PM
bill wilson's Avatar
bill wilson
bill wilson is offline
I have never done a compression test. I have always wanted to but eiter never have the time or the ambition. Ha. It is just mind bottling how it runs goofy but then sometimes it will run fine
Old 01-17-2015, 04:15 PM
427 fordman's Avatar
427 fordman
427 fordman is offline
What brand of vc gaskets/harnesses did you put in?
Old 01-19-2015, 12:15 AM
coreyallan01's Avatar
coreyallan01
coreyallan01 is offline
How many miles on the oil?
Old 01-24-2015, 03:24 PM
bill wilson
My gaskets are from accurate diesel. And I just change the oil the other day. There was only about 2800 miles on that oil change. BUT anothe thing, if I turn my TS upto the 100 horse position or the 75, and run it hard down the highway, and come to a stop, the missing and knocking goes away for quite a while but will come back and idle lower and act dumb again. So confused and frustrated..
Old 01-24-2015, 03:35 PM
427 fordman
Do you happen to know the brand that they sell?
Have you ever tried it with the chip out?
Old 01-24-2015, 03:40 PM
bill wilson
No idea what brand. Just says OEM made in the US for the type or brand I guess. And yes I unplugged the chip from the computer once before but I suppose Since I didn't disconnect the batteries it didn't reset? I'm not sure
Old 01-24-2015, 03:54 PM
ProjectDually's Avatar
ProjectDually
ProjectDually is offline
From what I've read, when the chip is unplugged, the PCM runs stock programming. The chip replaces that stock programming, only when plugged in, with the tunes on it.
Old 01-24-2015, 05:38 PM
MI02SVT's Avatar
MI02SVT
MI02SVT is offline
Just curious as what your fuel pressure is and if you have a gauge what your hpop is running no need to disconnect batteries with the chip just unplug the chip
Lead Head
07-01-2016 12:54 AM
GDSchafer
09-22-2015 04:38 PM
Dave Sponaugle
04-02-2010 04:30 PM
mustang_gt_350
11-21-2007 03:28 PM
Crossroads Auto
01-01-2006 10:33 PM
Quick Reply: Where should i send my IDM to?
