1978 - 1996 Big Bronco
351M hole in heads
Old 01-15-2015, 06:04 PM
tluns's Avatar
tluns
tluns is offline
351M hole in heads
Good Afternoon,
Need a little help. Just acquired an 81 Bronco with a 351M in it. After pressure washing and working on it for a few days I got it running. Now I find a hole in the heads that is spewing a little oil. The hole is approx. 1/2" located about an inch below the top of the head on the intake side between 2,3 and 6,7 cylinders. The hole on the right side does not blow oil and appears closed off. The hole on the left side is the one blowing a little oil. Can anyone tell me should this hole be plugged? Did I blow some kind of breather filter out of it when I pressure washed? What is the hole for? Any help is appreciated. These are factory heads and factory intake manifold.
Thanks, Tim
Old 01-16-2015, 11:59 AM
tluns's Avatar
tluns
tluns is offline
Figured it out.
Old 01-16-2015, 12:43 PM
rollerstud98's Avatar
rollerstud98
rollerstud98 is offline
So, what was it?
Old 01-16-2015, 01:13 PM
tluns's Avatar
tluns
tluns is offline
Exhaust heat dissipation hole. Probably full of 35 years of blow-by and such. When I pressure washed it I think it got water in it. As the water and gunk boiled off it appeared to be oil coming out. I got some absorbents and soaked it out last night and it appears dry. At least that's the story I'm going with right now.
Outlaw56
13
04-28-2014 05:43 PM
OldSchoolRodz
09-10-2005 12:49 PM
debestuss
07-25-2004 05:49 PM
Cmq44
Bronco II
04-08-2004 06:47 PM
JOEL
01-29-2000 09:49 PM
Quick Reply: 351M hole in heads
