Is swapping from 1/2 ton to 3/4 ton worth it?
I have a 75 f100 4x4 390, np435, I found a 77 f250 4x4 400m, C6, for $500 bucks. I have not purchased it YET. The body is just a rust bucket. Was told it has a 400m in it. I really want the truck to swap out my 3.50 9in and dana 44, for the 4.10s in the rear and front from the 77. Is this a difficult swap? Will it work? Did the f250 come with limited slip because my 75 has a limited slip in the rear? Should I just keep what I got an save up to regear to 4.10s.
first off, there is no 400m, its just a 400. IMO i would take the f250 and remove the whole body if it is that bad. Clean, scape,paint,sand blast or what ever you can just to make it look nice,then change your body over and sell your running gear. Jack the F250 rear end of the ground, spin 1 tire, if the other spins the same way its a posi, if it spins the opposite its and open carrier. Good luck with it,and post pic's.
IMO NO! All your gaining is 3 studs per wheel and more weight, i think its a waste of time and money.
anythings possible to do...but ,its not even close to a direct bolt in swap. the f100 frame is set up for front coil springs. the f250 will have front leaf springs. it also makes a difference if the f250 is an early 77 model ( high boy) frame, or late 77 model (not a high boy) because the high boy has a narrower rear frame section , and a divorced transfer case.
mswift
10-08-2005 11:52 AM
mswift
10-05-2005 01:34 PM
jj33s
03-04-2003 01:38 PM
Xwarrior86
11-25-2002 12:09 AM
