Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Ranger & B-Series
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Ranger & B-Series All Ford Ranger and Mazda B-Series modelsSPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-21-2003, 11:58 AM
Mooselighter's Avatar
Mooselighter Mooselighter is offline
Mooselighter is starting off with a positive reputation.
2.3L PCV valve
Is it true that some 2.3L Ford/Mazda engines do not have PCV valves? I can't find mine where the owner's manual says it should be.
It's one of those things I change out about once a year. On every other vehicle I've owned they have been fairly obvious, but not on this one.
  #2 (permalink)
Old 07-21-2003, 06:10 PM
hockeyfan_5000 hockeyfan_5000 is offline
hockeyfan_5000 is starting off with a positive reputation.
2.3L PCV valve
Hello,
I may be wrong but I believe the PCV valve is located underneath the intake manifold on a 2.3 liter. I would start by looking there. Hope this helps.
Travis
(hockeyfan_5000)
  #3 (permalink)
Old 07-21-2003, 07:57 PM
Rockledge's Avatar
Rockledge Rockledge is offline
Rockledge is a name known to all Rockledge is a name known to all Rockledge is a name known to all Rockledge is a name known to all Rockledge is a name known to all Rockledge is a name known to all
2.3L PCV valve
Looking under the intake manifold is worth a shot .....that's where the PCV valve probably will be, if it has one.
FWIW, the Ford Manual for a '94 Ranger 2.3 does not show a PCV valve anywhere. It says that year motor uses a "closed-type crankcase ventilation system" with the crankcase gases flowing through a hose (connected to the oil pan cover) and then down through a couple of oil seperators before being recycled back into the intake manifold. Could not find a PCV valve in any of the blowups, either. Maybe your year motor is the same type of setup?
HTH
__________________
'98 Ranger XLT 4x4 (4.0L)
'97 Taurus GL (3.0L Vulcan)
'94 Taurus SHO (MTX)
Ford Pics
  #4 (permalink)
Old 07-22-2003, 10:40 AM
dwildmanj dwildmanj is offline
dwildmanj is starting off with a positive reputation.
2.3L PCV valve
I thought I'd never find the PCV valve on my 97 Ranger, 2.3L.
It took a bit of patience and a small flashlight, but when you do find it, you won't believe that you looked over it so many times.
While standing at the front of the truck and facing the engine, look on the right side, and down between the manifold and the valve cover. If the 96 2.3 is like mine, the PCV valve sits on the level surface when you look straight down between the valve cover and manifold, almost directly behind the ac compressor/
  #5 (permalink)
Old 07-23-2003, 10:30 AM
2.3L PCV valve
What a pain. I kind of miss my old Comet with the 302 V8. That was a straightforward engine design. (sigh)
  #6 (permalink)
Old 07-23-2003, 10:36 PM
RedFordRanger RedFordRanger is offline
RedFordRanger is starting off with a positive reputation.
2.3L PCV valve
Trying to find the PCV valve on my 1995 2.3L Ranger. The auto books don't help me.
Please let me know where to find it so I can replace it.
Thanks.
  #7 (permalink)
Old 07-23-2003, 11:00 PM
nightme_02's Avatar
nightme_02 nightme_02 is offline
nightme_02 is starting off with a positive reputation.
2.3L PCV valve
Good luck.....that is the most difficult part on the whole truck to change...Chilton and Hanyes...neither give a good picture or description of were it is on a 2.3L...but it is near the Oil Seperater ( I believe somwere right above the Oil Filter) do a search through this forum, I found 1 good picture of it a couple months ago...even though I still haven't been able to see it on mine (94 2.3L) which is very similar if not the same to your 95...
Looks like the post is not there anymore...anyways there are some good moderators and senior members that maybe still have access to the pic and/or info that will better help you
  #8 (permalink)
Old 07-23-2003, 11:03 PM
nightme_02's Avatar
2.3L PCV valve
the PCV is under the intake and above the Oil Filter, hard to find. Good luck
  #9 (permalink)
Old 07-24-2003, 01:32 AM
Andywk's Avatar
Andywk Andywk is offline
Andywk is starting off with a positive reputation.
2.3L PCV valve
Quote:
HTH
I have a 94 2.3l and I have a PCV valve. If you are standing in front of the truck looking at the engine it is on the right side and almost all the way back. It is attached to a small black plastic hose that returns to the valve cover. It is not easy to get at or see either. My manual states that Ford will replace this free of charge at 60K miles. I took mine in and had them do it at this interval just because it was free. Only thing its been to the dealer for. I havn't had to change it since. I take it out and shake it and clean it once in a while but as long as I can shake it and make sure its free I figure it is working alright.
__________________
2002 PSD 4X4 CC SB SRW. Oilgaurd bypas filter, Autometer gauges, Tymar commercial intake, 4" exhaust, 203* Thermostat, SCMT
1994 XLT Ranger supercab 2wd. 245K miles and still going.
  #10 (permalink)
Old 07-24-2003, 02:43 AM
Rockledge's Avatar
2.3L PCV valve
Andy, is it possible then to just follow the hose from the valve cover and have it lead you right to the PCV valve?
__________________
Ford Pics
  #11 (permalink)
Old 07-24-2003, 02:15 PM
Andywk's Avatar
2.3L PCV valve
I just looked under the hood so I could be more specific. There is a hose running out from under the rear of the intake manifold on the drivers side. Must come from the manifold instead of the valve cover as I previously stated. It is really dark under there and I felt up along it as far as I could but never got to the end of it. I need a smaller hand for that. It comes out and curves down just between the intake manifold and the firewall. Right after it curves down is where the PCV valve on mine is located. The hose is on top of the valve and the other side of the valve plugs into another hose/tube that then goes down under the engine.
If you pull up on this hose the PCV valve will come out and be on the end of the hose. You can then put a new one on and plug it back in to the bottom hose/tube.
The Haynes manual for 93-97 ranger shows this on page 1-25. It is in illustartion 20.1a. The only confusing thing about this picture is the orientation of the engine. The first time I looked at it I couldn't make it out. Looking at it again there is an arrow locating the location of the front of the engine. Then it became clear.
Hope this helps.
__________________
  #12 (permalink)
Old 07-24-2003, 05:54 PM
RangerRuss RangerRuss is offline
RangerRuss is starting off with a positive reputation.
2.3L PCV valve
FYI: The PCV valve on my '90 Ranger is exactly as Andy describes. The valve is mounted in-line with a hose in and a hose out. It is indeed under the intake manifold between the oil filter and the firewall. Small hands helps. If you intend to buy a new one, take the old one with you. Parts house sent out the wrong valve twice @#$%^&..
Russ
__________________
2002 XL 2.3 Automatic
1998 Contour Zetec 2.0 - RIP 5/7/2009
  #13 (permalink)
Old 07-25-2003, 09:25 AM
2.3L PCV valve
Very helpful info from all.
The valve I picked up (listed in the Purolator book at the store) has two nozzles on the plastic end. This doesn't seem to fit with the "in-line" description above. Maybe I got the wrong part, too.
I'll take another whack at it this weekend. Thanks, guys.
  #14 (permalink)
Old 07-25-2003, 01:46 PM
2.3L PCV valve
The two nozzles on the plastic end is the same one that NAPA sent out to me. That is NOT the right one. It is one hole in and one hole out. I wish I could provide the correct part number but I threw the box away. I will look for the receipt.
Russ
__________________
  #15 (permalink)
Old 07-25-2003, 09:35 PM
2.3L PCV valve
The correct PCV valve is NAPA part number 2-9238. At least that is the one that fits my '90 4-banger.
Hope this helps.
Russ
__________________
Tags
1994 , 2002 , 2003 , 2004 , 23l , 94 , 97 , ford , hose , located , location , pcv , ranger , valve , vavle
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
