TRANSMISSION/ENGINE SIZE MATCH UP?
Need to know if a transmission for a '99 Expedition 5.4liter, will work as a replacement transmission for a '99 Expedition 4.6?
This is just a pretty good guess right now, but when I seen the Expedition and asked what his transmission issues were he said it would only drive in reverse. So he had someone change the filter & fluid. So just curious I pulled the transmission dip stick to look at the fluid, I'm pretty sure the dip stick was covered with engine oil.
For comparison I pulled the engine dip stick and set them side by side.
What ******* did this? They were identical.
So what would be the next step here? Is the transmission ok?
Crappieslayer0521
11-28-2018 02:36 PM
badgurl
08-24-2013 06:30 PM
DSMIT67
11-30-2002 10:29 PM
