Gloria: OBS build thread
#31
That wasnt my point tho; i was more interested in why not make the assembly more modular for service. I know thered be two gaskets in that scenario.. If machining wasnt an issue itd be the correct way to go about constructing the assembly; itd actually be even better if the upps were segrigated but retained together w a collar but thats a moot point now...
Andrew...my stix made the jump to an s400 logical.hehe
#32
#34
#35
#36
I got the interlocking style v bands as that side especially is under a lot of pressure and heat .
They are one of the last things I'm waiting to arrive. Installing that mess in one piece just seems like it would be hard on the bellows to Dow them that hard.
My drivers side up pipe is miserable to get in and out.last time I unbolted that side of the cab when I did the bellowed set last year. since andrew has his engine out it won't be an issue I don't believe.
#37
#38
I plan on placing them in a similar distance as the old slip joint or wherever they fit and are accessible
Then everything can be assembled loosly one part at a time. then tightened
Its all theory for me as i have not done this before.bill and I discussed having them on his build but he was in a hurry and they didn't arrive fast enough.
Andrew, sorry for hijacking your build.
#39
on
1 Post
Turbonetics uses v-band connectors on their up pipes.
I wanted to build mine similar to this, but didn't get the v-bands in time. I figured I would weld them up and then put the v-bands in later, but I put a bend in the passenger side up pipe to clear the 3 1/2" down pipe, and didn't have a long enough straight section on that side to put the v-band connectors in. Rather than start all over I plan on building another collector and pipes one day, using the v-bands. I have a mock up engine on a stand to do this, so it's really not a big deal.
You can see here the bend in the pass side pipe. After it was all said and done, and the down pipe was in, I didn't even need that bend there I don't think. I didn't have the down pipe to when I built the up pipes to gauge anything by, because I built the down pipe later.
#41
Looks like you're making good progress Andrew. There are a bunch of ways to do this. So long as it gets the job done, it works in my book! There's more than one way to skin a cat...
Yeah, that's dead sexy. Wonder what they would charge for a setup like that without the snail...
#43
#45
To address all the talk about Vband clamps, I think it's a great idea. That said, I suppose my approach was that I knew there were many T4 kits out there functioning well without them (all of irates kits utilize the style used here). And as mentioned, My motor will be out, so Im not too worried about the install. With any luck, they shouldn't need to be removed other than for mods that would warrant another engine removal.
Good to see this go up! I enjoyed chatting with you more this year than the previous, but I do remember the MANY passes you did in the range rover as well as seeing your back end pop-up from a couple launches this year.
Cant wait to see the turnout this year! Everyone's doing big things.
As a side note, that Rover was just traded up for the new 2015 model that's much lighter with an all aluminum frame. Ive driven it, it's very fast...; rumor is it will fun a higher 12 right off the lot.
