Pros and cons of cost friendly lowering options.
I'm to the point where I need to decide on the suspension for my 55 f100. I'm wanting to lower the overall stance but I would like to keep the original front and rear axel. What are your opinions of removing some leafs front & rear, lowering shackles, ect.... I guess I would like the front about 3 inches or so lower and the rear level with the front or close. I was using the search tool to find a thread related to this but had no success so sorry if this question has been addressed recently.
One of your better options would be to install proper lowering springs, like these from Posies. POSIES Rods and Customs ? Super Slide Springs ? Street Rod Parts ? Hot Rod Parts ? Truck Parts ? Ford and Chevy Suspensions and Chassis Parts » Dual Flex Springs With new springs, there's no guess work about worn/broken springs, poor handling issues, which or how many leaves to remove, etc. Better to be safe than sorry.
No question that's true, but not "cost friendly" perhaps. Totally depends what condition the existing springs, shackles, pins, bushings, etc are in. Also be aware of steering mods that may result from too low a ride (drag link/tie rods) -- more $$
A full set of the aforementioned Posies springs run about $700. Not free, but not bank breaking money, either. They include new U bolts for the front, eye bushings installed, the works. Add a set of pins and you're down the road all new and safe. No fuss, no muss. The drop isn't significant enough to cause ill handling. And since you're doing it all the way around, the caster isn't screwed up. It's the way I'm going.
Would be real nice to go with all new springs Wayne but don't think I can swing the $800-$900 to do that right now.
Scott, the ride height on your f-1 is exactly what I'm looking for. Did you have to make any steering mods? Do you think if I removed the same leaves on my 55 it would sit the same? Not sure on how different the two models suspensions are. Can you explain how to de-arch or would I need to take the top leaf to a shop? Thanks guys
Scott, the ride height on your f-1 is exactly what I'm looking for. Did you have to make any steering mods? Do you think if I removed the same leafs on my 55 it would sit the same? Not sure on how different the two models suspensions are. Can you explain how to de-arch or would I need to take the top leaf to a shop? Thanks guys
Also you need to watch oil pan clearance, depending on which engine you have.
Well........
Rear axle:
Remove leafs, longer shackles, flip the axle, move front spring mount up on frame. Everything there is pretty much free except the longer shackles.
Front Axle:
I think the only way to go is with one of Sids stretched axles in the height you want it lowered. I think they were $300.00 last time I checked. They eliminate oil pan issues, and retain the old look. You can then add on stuff as you go(rotors, springs, etc) that is if you want that stuff.
Had a Crown Vic front end not been dropped in my lap I would have went that route, sometimes I still regret not keeping it old school with the stock front axle.
Rear axle:
Front Axle:
The cheapest way is to remove springs. IMHO the next option is reverse arch the main springs (reverse eye springs) gets you 1 1/2 approx right there, than remove springs, in the rear raise the spring mounts, rear mounts to the front top of frame, front to rear pushed up to top of frame, nets you with the reversed eye approx 3" in the rear, if you go this route be careful to keep springs facing same as stock so you don't change the pinion angle. I did this on my 56, don't have anymore, and it was so close to tinman52's stance. One thing also in the rear I used all the springs so if I wanted it lower I could have removed springs
In my opinion, you can maybe get by with removing leaves, but I doubt you'll be really satisfied until you save up and sort of go all in. Lowered springs along with a drop axle yields a pretty darn good look in the front. One without the other doesn't quite do it for me. But the nice thing is you could do the springs now and the drop axle later. On the rear, again, leaves will get you started, but to get "the look" you're probably going to want extended hangers and to move the brackets up, or to flip the axle on top of the springs, things that are going to cost a little bit of money. It does tend to snowball, so you need to have some money saved up. If you could set aside $1000-$1500 I bet you could get a nice stance and be ready to cruise...probably even quite a bit cheaper if you just remove leaves or maybe just do a main leaf modification.
I went the expensive/cheap route and used new lowering springs/kits front and rear (about $1400 from mid fifty), a Sid dropped axle ($360 with shipping and sending a core), lowering rear brackets ($100), hd tie rod and dropped tie Rod ends ($125). Not cheap, but convenient and I'm happy with the results. No engine or transmission in the truck yet.
