relay wiring help!
relay wiring help!
hi guys I recently installed a remote start/keyless entry system in my 03 SD everything is done except for the keyless entry part of it I wired it up according to the 5 wire set up on this page Car Security and Convenience, Power Door Locks, Multiple Wire Systems, Add Auto Lock/Unlock but when I try to put my fuse in for power it blows every time can someone shed some light is this even the correct way to wire them up! thanks
Was your truck originally equipped with remote keyless entry from the factory or not?
The interface with an aftermarket RKE is completely different between the factory RKE system and the basic PDL system.
If factory RKE, all you need is a negative pulse on the lock or unlock inputs of the VSM. If basic PDL, then you need the relay arrangement that will directly control the actuator motors.
The circuit/relay wiring OP shows is one I've used more than a few times as a secondary or remote trigger for factory PDL's.
Glad that was all it was----paying close attention to small details like this sometimes trips us up----I run into it myself more than I like admitting.
Primetime1
Electrical Systems/Wiring
01-31-2019 01:42 PM
merkstang
1978 - 1996 Big Bronco
01-13-2004 02:46 PM
