1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2009 F-250 V-10 - Lowest Gears Possible
Old 01-13-2015, 06:30 PM
cecilt's Avatar
cecilt
cecilt is offline
Currently have a '09 F250 V-10, CC, 4x4, Lariot with 4.10 gears. Might want to go to Toyhauler that would weigh loaded close to 15klbs. Would swapping in 4.56 gears be a vast improvement for towing performance? What is the lowest you can go? We live in SW VA so have hills and mountains to tow in. Is this too much weight for a V-10. Length will be under 40'.
Old 01-14-2015, 05:21 AM
redford's Avatar
redford
redford is offline
Received 1,561 Likes on 909 Posts
Do you have stock tires?
15000 is right around or just over your maximum recommended weight. Your truck can handle it, but be careful. When calculating, make sure you include all of your cargo.
Your truck was also offered with 4.30 gears, which added about 1000 pounds to the max recommended towing weight.
Old 01-14-2015, 06:28 AM
Tom's Avatar
Tom
Tom is online now
Going from 4.1 to 4.56 would be a 10.1% improvement in torque to the ground in a given gear.
And no, it's certainly not too much weight for your engine. That engine is offered in the F-650 with a GVWR of 30,000 lbs. That trailer may be a bit too much for your chassis however. Are you looking at a 5th wheel or conventional trailer?
Old 01-14-2015, 07:21 AM
cecilt's Avatar
cecilt
cecilt is offline
I have the optional 20" wheels. How much does these reduce my tow and or payload vs the stock 18's? Tks.
Old 01-14-2015, 08:02 AM
senix's Avatar
senix
senix is online now
Received 1,415 Likes on 1,010 Posts
Not sure how much the 20's reduce what you can tow but I think going to a 18" rim would be better.
4.30 gear I would think would be great.
You won't want to travel as fast (ground speed) with the lower gears but It should help it to stay in the power band.
Here are the towing guides:
Towing Guides | fleet.ford.com
Old 01-14-2015, 10:22 AM
cecilt's Avatar
cecilt
cecilt is offline
Thanks for the towing guide. From this not worth the cost to swap in 4.30 gears from the 4.10's just to gain 1k in GCVR and best to stay at 12k lb or under for loaded camper.
Old 01-14-2015, 10:51 AM
C-Jones Lawn & Tree's Avatar
C-Jones Lawn & Tree
C-Jones Lawn & Tree is offline
without getting into a complicated chart of torque/hp values & bandwith comparisons, would the 4.30 improve mpg? or because the top end speed is slightly decreased, it would not?
Are the stock 4.10 gears the ideal for hauling/towing mpg? I am trying to determine what gears my v10 F250 has & if they are the reason my mileage appears to be lower than everyone else's (or if they are simply lying lol).
Old 01-14-2015, 10:56 AM
C-Jones Lawn & Tree
For comparisons sake, it did a gear swap in a vehicle previously & saw little to NO torque gain. Of course, it in no way compared towing or power-wise to the F250...1988 Toyota Landcruiser 12.5" suspension lift w/ stock A440f auto tranny & stock I6 4.0L...4.11 gears stock...swapped to 4.88s...identical mileage, performance, speed, etc. Didn't see the $1K spent lol constantly thought about WHY I didn't install the 5.29s but then wondered if they would have improved anything either.
Again, I do realize this is no real comparison "vehicle or even usability wise" (Cruiser towed little, offroad/trail use much).
thanks
vjstangelo
04-16-2014 12:17 PM
wlhm
Modular V10 (6.8l)
08-22-2008 12:25 AM
Geneoh
Modular V10 (6.8l)
76
04-12-2008 07:01 PM
pooldude
Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing
04-09-2008 08:27 PM
HOSSS222
Modular V10 (6.8l)
03-02-2008 02:53 PM
Quick Reply: 2009 F-250 V-10 - Lowest Gears Possible
