04 Ford Explorer 4.0 Bank 1 & 2 Lean
Hi Everyone.
My 04 Explorer 4.0 has been giving me the bank 1&2 lean codes. It is the fully electronic throttle body not mechanical. It seems from reading that in 04 is when they switched to the electronic version. Here are some things I have done to resolve this. I created a diy smoke machine from a paint can and air. I found a leak by the egr. I replaced the egr and gaskets, along with the metal part that goes into the throttle body. I replaced the pcv and hose(although it looked fine). I replaced my intake gaskets. I replaced the MAF sensor.
Before all of this my lt fuel trims were +25 for both bank 1 & 2. After doing all of this my trims did come down a little to Bank 1 +16 and bank 2 +23. I dont know what to check next! If you have any ideas I would really appreciate it.
I forgot to mention I also replaced both upstream sensors. With Bosch not oem. If I remember I remember correctly the readings for bank 1 and 2 would fluctuate between .2 and .8. I will have to double check that though by purposely inducing a rich condition.
Torgmada
1983 - 2012 Ranger & B-Series
05-05-2011 11:33 AM
1998Ranger25L153CID
02-01-2010 04:10 PM
chayes01
12-29-2009 09:41 PM
