Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1948 - 1956 F1, F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Old 01-12-2015, 09:12 PM
Harrier's Avatar
Harrier Harrier is offline
Harrier is a name known to allHarrier is a name known to allHarrier is a name known to allHarrier is a name known to allHarrier is a name known to allHarrier is a name known to all
Hammer and Dolly set questions
Seeing you guys do some of this body work makes me want to start beating on metal. So I started looking for a cheap hammer and dolly set and found this for next to nothing: http://www.summitracing.com/parts/wmr-m7007
I know you get what you pay for, but I'm way below novice.
AxRacer said this: "Since all he had in his shop was a basic set of Harbor Freight “clubs and rocks” (their version of body hammers and dollys) I also showed him some of the hammers and dollys I use most often and what makes them a superior tool to work with, and suggested he surf ebay and be picking up a few used but professional quality tools." which makes a lot of sense.
Here is the thread by the way: http://www.ford-trucks.com/forums/13...g-try-2-a.html
So, my question to you experts. Is it worth the $25 bucks to get a cheap set and get a feel for moving metal around, or should I look for something a higher quality to start? I'm a long ways from doing real body work.
Another question, if you are looking for better used hammer and dolly sets, what do you look for?
__________________
Joe
1955 F-250 239 Y-Block
Y-Block Restoration Thread
Old 01-12-2015, 09:22 PM
raytasch's Avatar
raytasch raytasch is offline
Old guy with old toys
raytasch is a splendid one to beholdraytasch is a splendid one to beholdraytasch is a splendid one to beholdraytasch is a splendid one to beholdraytasch is a splendid one to beholdraytasch is a splendid one to beholdraytasch is a splendid one to behold
My experience with cheap tools is handle attachment. I spent more time tightening handles than working.
__________________
Ray
1949 F-4 Built to drive--script bed.
1956 F350 Stock rebuilt script bed
2007 F150 SC. Driven once in a while. 2015 Escape SE EB 1.6 Wife's ride
Government conceived by genius, now operated by fools.
Old 01-12-2015, 09:29 PM
FortyNiner's Avatar
FortyNiner FortyNiner is offline
FortyNiner has a great reputation on FTE.FortyNiner has a great reputation on FTE.FortyNiner has a great reputation on FTE.FortyNiner has a great reputation on FTE.FortyNiner has a great reputation on FTE.
I got this set from Eastwood and have been satisfied with the performance: 7 Piece Pro Hammer & Dolly Set - Fiberglass Handles - Eastwood
__________________
19 and 49 F1 jes' like Henry II built
DW
Old 01-12-2015, 09:32 PM
bobj49f2's Avatar
bobj49f2 bobj49f2 is offline
bobj49f2 is a splendid one to beholdbobj49f2 is a splendid one to beholdbobj49f2 is a splendid one to beholdbobj49f2 is a splendid one to beholdbobj49f2 is a splendid one to beholdbobj49f2 is a splendid one to beholdbobj49f2 is a splendid one to beholdbobj49f2 is a splendid one to behold
When I worked in the body shops I always had a fairly basic set of tools. For body work I had a couple very good quality body hammers and about six different body dollies of different shape. The tools I have aren't the most expensive but they aren't Harbor Quality either. When I first started I bought some cheapie tools and found out quickly they just didn't work right. I think I bought both hammers from Sears, through their catalog at the time. While the other guys in the shop had huge tool boxes filled with Snapon tools I could do just as good with the small amount of tools had.
Whenever I buy tools I buy the best I can afford but that doesn't mean I break the bank buying the most expensive. I suggest to anyone starting out to not buy the cheapest, start out with tool company that you would trust that you've used for other tools.
__________________
Old trucks, it's a sickness-one I hope they never find a cure for!
Bob Jones--Fat Fender Aficionado--FTE member since '96
49 F-2 pickup/48 F-1 panel truck
48/51 F-4 flatbed (2 in 1)/49 8N tractor
www.fatfenderedtrucks.com
Old 01-12-2015, 09:42 PM
tinman52's Avatar
tinman52 tinman52 is offline
Welder User
tinman52 is a splendid one to beholdtinman52 is a splendid one to beholdtinman52 is a splendid one to beholdtinman52 is a splendid one to beholdtinman52 is a splendid one to beholdtinman52 is a splendid one to beholdtinman52 is a splendid one to beholdtinman52 is a splendid one to behold
Yep, that set from Summit are clubs and rocks. Almost identical to my first set I got some 30 years ago. I still have the dollies, you cant hurt them. Broke all of the hammers(they are cast iron).
The problem with cheap tools is you can do more harm than good with them.
I have found some nice hammers at garage sales.
That Eastwood set doesn't look too bad...
__________________
Scott
'99 F250 SD 4x4, '62 F100 4x4, '52 F-1
My COE build thread;
http://www.ford-trucks.com/forums/11...uck-build.html
"you can call a pig a duck, but that won't make it quack!"
Old 01-12-2015, 10:14 PM
rhopper's Avatar
rhopper rhopper is offline
rhopper has a good reputation on FTE.rhopper has a good reputation on FTE.
I have a cheap set and I also use the good quality Martin's my son has. I can't put my finger on it but the Martins just seem to work better. I know just from examining them the Martin brand uses a different grade of steel.
__________________
Measure with a micrometer, mark with a crayon, cut with an axe.
Old 01-12-2015, 10:56 PM
52 Merc's Avatar
52 Merc 52 Merc is offline
52 Merc is a splendid one to behold52 Merc is a splendid one to behold52 Merc is a splendid one to behold52 Merc is a splendid one to behold52 Merc is a splendid one to behold52 Merc is a splendid one to behold
Don't overlook used tools, which can be commonly found at pawn shops, yard sales, craigslist, ebay, etc. A lot of times you can find good deals on quality tools. It's hard to hurt a good set of body hammers and dollies. Better quality tools have better balance and the correct shape on the head striking surface to do the job at hand. You could do the same with a claw hammer as with cheap body hammers. Good body hammers are designed to move metal in particular ways, and help you do your work correctly.
__________________
Wayne
52 Mercury M-1
among other things.
Old 01-12-2015, 11:39 PM
ChuckRob's Avatar
ChuckRob ChuckRob is offline
ChuckRob has a great reputation on FTE.ChuckRob has a great reputation on FTE.ChuckRob has a great reputation on FTE.ChuckRob has a great reputation on FTE.
They bought some Harbor Freight sets for the school and none of them lasted the semester without the heads breaking off. I have a set from Eastwood that I am happy with and they are not that expensive. Watch for their sales.
__________________
What Toy Should I Play With Today
Still A Kid After All These Years.
Old 01-12-2015, 11:45 PM
Harrier's Avatar
Quote:
That's the main reason I asked the question. If I want to learn I don't want to learn with tools that will hinder my learning, but I don't want to have to rob a bank to try to learn a skill.
Thanks for all the tips guys.
So, is there a price point for a set that has good enough quality? Is that $70 set about the lowest to go? Well...if I can find a used set....
I really don't need to be spending money on these at the moment, but there are several really good threads with body work going on it makes me want to explore that area. You guys are enablers without really even trying.
__________________
Joe
Old 01-12-2015, 11:47 PM
Harrier's Avatar
Quote:
I didn't think about pawn shops...good idea.
__________________
Joe
Old 01-12-2015, 11:49 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe Jolly Roger Joe is online now
Unobtanium Man
Jolly Roger Joe is a splendid one to beholdJolly Roger Joe is a splendid one to beholdJolly Roger Joe is a splendid one to beholdJolly Roger Joe is a splendid one to beholdJolly Roger Joe is a splendid one to beholdJolly Roger Joe is a splendid one to beholdJolly Roger Joe is a splendid one to behold
Quote:
By now, you should be thinking about body and fender repair in your sleep.
You're getting drowsy...
Your eyelids are getting heavy...
Listen to the sound of my voice...
You want to be like AXracer... (good luck with that)
You need another truck to practice on...
__________________
Joe
51 F4 "Betsy" http://www.ford-trucks.com/forums/10...4-project.html "If you think you can do a thing or think you can't do a thing, you're right." Henry Ford
Old 01-12-2015, 11:54 PM
Harrier's Avatar
Of course I love old tools:
Click the image to open in full size.
I also just saw they sell rubber sets. I think our trucks would laugh at those.
__________________
Joe
Old 01-13-2015, 01:00 AM
52 Merc's Avatar
For 20 bucks, you can't go wrong with those, Joe. They appear to have enough experience they might even teach you a thing or two.
__________________
Wayne
52 Mercury M-1
among other things.
Old 01-13-2015, 06:53 AM
CharlieLed's Avatar
CharlieLed CharlieLed is offline
CharlieLed is a name known to allCharlieLed is a name known to allCharlieLed is a name known to allCharlieLed is a name known to allCharlieLed is a name known to allCharlieLed is a name known to all
I attended a workshop with Ron Covell and learned quite a bit about hammers and dollies from him. There are some parameters that should drive your choice in hammers and dollies; the size and shape of the head of the hammer and the size and shape of the dolly make a big difference in the quality of the work you can do with them. I spent the extra $$$ and bought Martin tools. That said, Ron Covell uses a couple of HF dollies as well...these are vise mounted dollies and are drop forged. Sometimes you need a dolly that is more of an "anvil" than a handheld dolly, these work great and they are CHEAP.
I would suggest that you get a copy of one of Ron Covell's DVDs, he has a beginners video on metalworking where he discusses various metal working tools. It's good to watch a master at work.
Old 01-13-2015, 10:24 AM
mustangmike6996's Avatar
mustangmike6996 mustangmike6996 is offline
mustangmike6996 is starting off with a positive reputation.
I have a 7 pc I think, Matco kit and it works pretty well. I think I got it for less than 100 bucks
__________________
2013 F150 Eco
1969 Mustang Fastback 331 4-speed, needs paint
1951 F1 4.6L DOHC, Tr3650, 8.8
Gone- 96 Stang, 06 Stang, 10 Stang, 08 F150, 04 HD F250, 10 Raptor (I enjoy cars/trucks too much)
Similar Threads
F1 fender rust repair and patch forming. TRY 2 AXracer 1948 - 1956 F1, F100 & Larger F-Series Trucks 59 01-01-2015 02:54 PM
Rust repair and patch panel forming AXracer 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 12-02-2014 12:43 PM
Sunday in the garage turnrjr 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 01-07-2013 03:43 PM
Excellent body work reference book AXracer 1948 - 1956 F1, F100 & Larger F-Series Trucks 13 12-18-2012 08:46 AM
Body tools reg1952 1948 - 1956 F1, F100 & Larger F-Series Trucks 42 12-19-2007 02:31 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
