92 f250 only starts with ether fuel pumps stay on
Old 01-11-2015, 06:50 PM
markjones333's Avatar
markjones333
markjones333 is offline
Hello my name is mark i have a 92 f250 custom that has a problem. I have a 5.8 (351w) i jumped in it after work and on the drive home she was missfiring and not going over 20 m.p.h. i had her toed home next morning she wouldnt start. Spraid some starter fluid in her she fires up but she ether stalls out when driving or she missfires when you try to give her gas. When you turn the key the fuel pump stays on without shutting off like it should. Brand new fuel pump fuel filter and new alternator. Im starting to believe i have a bad pcm/eec. Any suggestions?
Old 01-11-2015, 09:24 PM
Conanski's Avatar
Conanski
Conanski is offline
Yes when the fuel pump runs continuously before the engine is started that indicates a bad PCM.
Old 01-11-2015, 09:25 PM
markjones333
Any idea where the pcm is located on this truck?
Old 01-11-2015, 09:32 PM
Conanski's Avatar
Conanski
Conanski is offline
It's in the drivers side cab fender but is accessed from the engine bay by first disconnecting the wiring harness.. the rectangular shaped connector not the round one. Make sure you disconnect the battery first before anything else.
Jon_C
1999 to 2016 Super Duty
03-11-2017 06:51 PM
markjones333
01-12-2015 11:42 AM
TaddyBare
03-17-2014 05:56 PM
JoePeeper
10-23-2013 04:24 PM
feirmeoir
12-08-2004 10:38 PM
Quick Reply: 92 f250 only starts with ether fuel pumps stay on
