Transmission swap??
Old 01-11-2015, 10:05 AM
Chaulky8's Avatar
Chaulky8
Chaulky8 is offline
Transmission swap??
I've got a 89' f250 351 with a zf5 and a 83' f150 300 straight six with the granny four speed.
I'd like to swap my transmissions and put the zf5 behind the straight six, will they marry up or do I need to do a lot of retro fitting?? Thanks for any help
Old 01-11-2015, 10:21 AM
dylansf23's Avatar
dylansf23
dylansf23 is offline
They Will fit. Look at my build thread. You'll have to get driveshafts cut and hope one of the cross members is useable for the farther back transmission. Then you'll need to either manually move your trans cover to fit, or use the zf5 one. It's a lot of work, but in hindsight it's easy job.
Old 01-11-2015, 10:28 AM
Chaulky8's Avatar
Chaulky8
Chaulky8 is offline
Thanks Dylan
How would I find your build tread? I'm brand new to this site.
Old 01-11-2015, 10:29 AM
dylansf23's Avatar
dylansf23
Click on my name, go to threads started and it's finallya build thread or something like that
Old 01-11-2015, 10:43 AM
Chaulky8's Avatar
Chaulky8
Chaulky8 is offline
Found it.
I found it!! The biggest thing I was worried about was the bell housing marrying up and the pilot shaft on the transmission being the same.
Basically I'm wanting the overdrive in my 83'.
Old 01-11-2015, 10:45 AM
AbandonedBronco's Avatar
AbandonedBronco
AbandonedBronco is offline
The 351, 302, & 300 all share the same bolt pattern so you can swap them all around, as well as the transmissions.
I *think* all the manuals have the same length shafts and are mounted in the same place, so it might be really straight forward. It's when you switch around with autos that length changes really enter in.
dylansf23's Avatar
dylansf23
I wanted the diesel gear ratio but it wouldn't fit from the bellhousing. It bolted right up. My first experience with a internal slave. Not hard to bleed either. Coulda been worse
Old 01-11-2015, 10:48 AM
dylansf23's Avatar
dylansf23
No the small block zf5 is around 2.t" longer then a 4x4 t18. I had to use the different ears for my crossmember drill a second hole and put a plate on my crossmember. Then I had about 2.5" cut and extended on my driveshafts(300$) .
However all the other manuals from that era are the same length.
Old 01-11-2015, 11:10 AM
Chaulky8's Avatar
Chaulky8
Chaulky8 is offline
What about the transfer case?
The transfer case on the 83' is in great shape can I use it on the back of he zf5 or will I need to use my one that's on there?
Old 01-11-2015, 11:29 AM
dylansf23's Avatar
dylansf23
All Ford tcases mount to each other. They have the same output shaft and gasket.(until newer ones(superduty era and the split f150, and honestly I don't know if they are the same or not) )
Old 01-11-2015, 11:36 AM
Chaulky8's Avatar
Chaulky8
Chaulky8 is offline
Thanks
Thanks so much you guys this has helped me so much. I'll let yA know how it goes.
Old 01-11-2015, 11:39 AM
dylansf23's Avatar
dylansf23
If we helped ya, rep us!
Sosa
04-20-2019 05:49 PM
Secallaw5
06-30-2018 08:41 AM
Meatwad440
1999 to 2016 Super Duty
02-22-2011 11:54 PM
Guntar
02-08-2010 09:19 PM
charlez
06-22-2001 06:55 PM
Quick Reply: Transmission swap??
