HOWTO: De gum your ignition lock mechanism.
I see this get complained about a lot. And the answer is simple.
Simply remove your steering wheel, ignition cylinder lock, take the snap ring out holding the gear in.
Remove the screw holding the steering wheel lock/ gear rack in. Degrease everything, take a small cloth rag and a long skinny screwdriver and clean out the rack gear/shaft hole as best as you can. Now that everything is clean, reassemble most of the way. To the point you can actuate everything. Use the CRC Heavy Duty Silicone lubricant. You can find this at Walmart. Spray everything in there down very well. And it's best to spray in down past where the ignition lock sits, before you install it. Work the mechanism quite a bit. Let it dry, spray it again a couple more times. Put your steering wheel back on and it's good to go.
The grease the factory put in there has become dry over the last 30-35 years, collects dirt and gets gummy. The silicone dries and leaves a non stick film so no dirt will want to collect and cause a gumming problem ever again. I did this months ago and it's been super easy to actuate in 20 degree weather.
The following users liked this post:
no not yet. got distracted by a new issue with higher priority... the famous mechanical choke as the temp got down here in texas truck start well but stay in choke position until ambiant temp warm up late rin the day.. found line going to mechanical thermostat broken at exhaust manifold. been researching topic all around to find an easier fix rather than have to go to the exhaust manifold removal and cleaning of where that tube goes. in the mean time for the start side issue, i just bring back the key into the correct position after the engine start until i can get to the cleaning procedure you send me the link for..
appreciate...
appreciate...
Right you are sir, It was in the middle of winter, I had to use channel locks with cloth wrapped around the switch to get it to turn, So I decided the easy way was better than nothing, How ever I will do it the proper way at some point.
fomoco88
32
05-24-2021 04:55 PM
