1951 F1 - Vent window - Ford Truck Enthusiasts Forums
Old 01-09-2015, 08:51 PM
rneithammer rneithammer is offline
rneithammer is starting off with a positive reputation.
My right side vent window is missing the latch...and I'm sure I know why. I have a correct NOS latch, but how do you install that? It looks like the frame has to come off the glass first. I'm sure I'd trash it if I tried. Is there a specialist out there that would take this on?
Old 01-09-2015, 09:30 PM
Doc's Avatar
Doc Doc is offline
Doc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud of
You are the "specialist". You can do it. All you have to do is put some duct tape, a thick rag, or rubber on that glass and pull it out of the frame gently with a wide clamp or pair of pliers. One of those vice grips with the wide mouth for shaping sheet metal would probably do an excellent job. You might be surprised at how easy it will come out. Then drill out the broken latch piece and pop-rivet the replacement lever in place and tap the glass back into place with a rubber mallet or something similar. If you break the glass, it's no big deal. Just order a new piece.
Post your location specifically (not just the state), and there might be someone nearby to help if you still don't feel comfortable with it.
Power windows and power door locks advice Bojohnson 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 09-27-2016 05:39 PM
help on vent window repair scottlathrop 1961 - 1966 F-100 & Larger F-Series Trucks 5 08-02-2015 08:04 PM
Vent Window Latch jeff2761 1961 - 1966 F-100 & Larger F-Series Trucks 0 07-11-2015 11:09 AM
vent window latch abyars111 1967 - 1972 F-100 & Larger F-Series Trucks 12 04-17-2015 12:28 AM
vent window latch? ghostwhite 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 10-15-2010 09:26 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
